Rough idle even with new engine mounts
    I finally got fed up with my 91 LX shaking badly (enough to shake the whole car) when idling so I took it to Honda and they found the front engine mount was cracked and replaced it. All seemed well when I picked the car up but then later that day the car resumed shaking. Could it be something other than the mounts? Because it's also been idling low. In park and neutral: 500-600 rpm, in drive and reverse it goes between 200-400 rpm (it's an auto tranny). Any help or advice would be greatly appreciated!
    edit: the shaking get's worse with the A/C on
    Does the shaking go away while driving? Or is it shaking even than?
      It goes away when driving. As long as the RPM's are up the shaking goes away
        The front mount is not a load bearing mount. That wouldn't have been the cause for the shaking in the first place. Shame on Honda for that diagnosis... The other 3 mounts would be far more likely to be an issue. I'd check those, as the guys at your Honda dealership may not have been smart enough to do so.
        The low idle may be part of it. Set the idle properly. Always start with what you KNOW to be wrong, and go from there.
          Its most likely your rear mount. I bought a rather decent quality aftermarket mount here locally for my 90 EX 5spd put it in and the shaking was still there.
          I put it off for a long time since it was a bitch to install and I ended up damaging my heater core, enough to where I actually had to completely take it out to find out that all I did was bend the inlet and outlet lines.
          I finally got fed up with it shaking at idle and converted to an LX/DX 5spd rear mount and bracket. Car is smooth as butter now.
          So if you have an EX 5spd, I would ditch that mount setup in favor of an LX/DX 5spd mount and bracket. No matter what I did, the shaking was there with that original mount.
          member's ride thread
          91 Accord SE 176k
            I have that shake on my car it shakes the weel alot... Ended up zip tie'ing it to the closed position and it feels okay but I'm going to replace it even though it's just over a year and 1/2 old ....
            Originally posted by evil_demon_01
            Do it once, do it right.
            Saving a dollar is not worth risking a life.
            Missing My
            White -91 LX Sedan - leather converted
            Mulberry 91 EX Sedan
            The project 92
