UPDATE: Believe problem to be fixed, loose ground near T-stat housing
So I've got a 93 EX 5spd 293k F22A6. About 2 months ago it started cutting out when driving if you didn't let it warm up, and only for about 10-15 minutes then it would clear right up. For the next month or so I would just let it warm up before I left and then it would be fine. When it cut out I could hear the main relay clicking, the CEL and Batt light would all come on. It would just cut out for a second and pick right back up, and not just like a single cylinder cut out, this was a very violent full engine cut out.
Fast forward about a month. Driving home one night it wouldn't stop cutting out and basically got to the point that I couldn't accelerate or keep speed. I could push in the clutch and the RPM would increase and slowly start to fall. It also smelled of raw fuel (seems like a spark issue, not fuel). The tach was jumping around +/- 5k RPM.
Battery checks out fine, Alternator checks out fine.
Symptoms are Cutting out but not dying completely (only once). Main Relay making a lot of noise, check engine light and battery light both come on, and tach jumping. It will idle just fine touch the gas and get the RPMS around 2k-2.5k and it starts going crazy.
Trying to figure this out without throwing a bunch of parts at it or taking it to a shop, its just a commuter and I didn't pay very much for it. Could it be the dizzy/Ignition module, Main Relay?
