anyone have pix of the jdm grill that is used with the 90-91 jdm headlights with the chrome trim? never seen it nor know what to look for. i would like to get one as the usdm grill does not fit properly. thanks!
JDM grill for 90-91 jdm headlights
Originally posted by ikaytothe jdm 90-91 grill is thinner to accommodate the chrome trim joesue.
theres a jdm 90-91 grill on ebay; the jdm one also has a filled in H instead of a hollow backing for the H like the usdm.The beginning of a new era............................
IT LOOKED fine to me when i had it.
you can get the one piece brows that go from left to right headlight connecting to the factory grill...those are rare, and maybe a little fugly.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by CB7.v2anyone have pix of the jdm grill that is used with the 90-91 jdm headlights with the chrome trim? never seen it nor know what to look for. i would like to get one as the usdm grill does not fit properly. thanks!
Both cars have the 90-91 JDM 1-pieces with chrome trim along with the JDM grille With my car, the JDM grille still overlaps in front of the headlights' trim a little bit. Still fits a lot better than the USDM grille though..Mike's seems to fit a little better than mine, his looks more flush..
Hope that helps..
Ronald
oh i remember now...i just made the grill stick out a bit and it blended perfectly to my headlights.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztechoh i remember now...i just made the grill stick out a bit and it blended perfectly to my headlights.
Originally posted by ikaytofound a nice up close shot
f22-dohc
So yeah, better double check..If your car's been in an accident, maybe things won't line up as well hehe
Ronald
if mine didnt fit, the grill stuck out maybe 2 mm more than the headlights...but it worked.
mine was in a front end incident so that could of played a role, but it was maddd sexxy.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
