93 honda accord se exhaust
    ok so i have a 93 honda accord se and im having trouble with some exhaust work. im almost certain that the motor is an f22a1 (please correct me if im wrong) but i need a new header and i cant find the stock one anywhere. also some one told me about a non metal gasket for the header. they said it was like a rubber/silicon material. Any info/advice on that would be nice too.
    Why do you need a new header?
    If you're looking for a stock one just go to the junkyard. Any 92-93 EX or 91/93 SE will have the exhaust manifold you need.
    And don't use a rubbery silicon gasket maker. They suck and will blow out and leave you with a leak. use the two oem donut gaskets that sit in the top of the down pipe.
      You need a metal gasket.
      Your engine is an F22A6, unless it has been swapped out. You can look at the spot to the left of the header for the engine code.
      Finding a new stock replacement is going to be difficult. I would just buy OEM Honda gaskets, and pick up an aftermarket header, such as OBX or Megan Racing. You won't gain much performance, but those will be cheaper than a new OEM piece.
        i just grided the header so there is no bumps now...but when i put it on there is still something smoking. Im hoping there is just a leak but im not too sure. The bolt/nut all the way to the right is the hard one to get to and tighten so im hoping thats just not tightened down enough...Ive been using 32 ftlbs bc thats what the ex uses. Does anyone know exactly what i should use for a 93 Accord Se
          The torque specs are not going to vary for the exhaust between the EX and SE. If you're that anal about it, be sure to follow the specs for a 92-93 EX. They have the exact same engine.
