My baby wont start anymore
    My car was overheating. I changed the radiator(which was rotted out), new hoses and new thermostat. Went to get an inspection and passed. Went inside to watch deadliest warrior. I went outside to start the car. It ran for about a minute. I turned it off cuz I wanted to go to the store and grab a malta goya. I went back to start the car and it would not start. The battery light doesn't come on anymore. I've been pushing the car for a week now. I can't figure it out. Plz cb7 help me!!!!!
    Dizzy is brand new!
    My coupe!!!
    Originally posted by Racer_XXX
    fuel pump?
    i know you replaced the main relay already
    hmm
    http://i220.photobucket.com/albums/d...82408002-1.jpg
      Originally posted by bobbycos View Post
      fuel pump?
      hmm
      I got the fuel pump in my lumina. I just don't want that to be the necessary repair. Why me?!
      My coupe!!!
        Determine if you have your 2 elements: fuel and spark. Then you can start to determine what the problem is.
          actually its 3 things
          spark
          fuel
          compression
            I just threw in a new dizzy. Still no start. Now, like I said before,, my batter light doesn't come on when the ignition is on. My prob has to be electrical! It just has to be!!!!!!! Car cranks but no start
            My coupe!!!
              check the fuses.try the ecu 0ne first.
              my new turbo build
                spark
                fuel
                compression
                actually, it's 4 things. air, fuel, compression, and spark. later.
                Avoiding dirt at all costs
                  i stand corrected , thanks
                  did the fuses pass the test?
                    you said you've been pushing the car for a week. Does that mean pop starting it? Or will it not run at all...
                    http://www.cb7tuner.com/vbb/showthre...=1#post1823428
                    My Custom BB6 Dash Swap Thread
                      I had a problem similiar to this once. I bought brand new NGK plug wires and put my 4yr old crane cams wires in my toolbox. Car was starting and running great, then, like someone flipped a lightswitch, it would crank and crank but not start. I tried everything I could think of, then finally put my old plug wires back on and it fired up first try. I just left the crane cams wires on and still have never had a problem since.
                      Try new wires and see what happens...
                        pushing it from side to side of the street
                        we have alternate side of the street parking for street cleaning purposes.
                        in our hood the time for moving your car is 8:30 am to 10 am, Monday to Friday
                          In Hunts Point its 12-12:30.
                          But thats besides the point.
                          Anyways man, i would try a compression test.
                          Check your oil, is it milky?
                            Oh man, bummer. I hope you get this figured out soon!
                              All fuses pass the test man!!!
                              Im going to check my oil when I get ready to push tomorrow.
                              But if my battery light is doesn't it something electrical?
                              My coupe!!!
