Third Brake Light
    Third Brake Light
    Has anyone ever come across the brake light on the rear deck not working on a 92 ex. I have power to the box on the passenger rear brake light but it won't supply power to that light unless I use a power probe.
    Is it possible you have a broken connection somewhere?
    I would check for:
    • Ground at the connector
    • Possible broken connections (use multimeter with option for continuity testing between the wire and ground in case it shorted out somewhere)
    • Check the 3rd brake light connector if it just came loose
    • Possible faulty fuse
    Check those and post results, we can go on from there
      I have gotten all the brake lights working, it was the passenger outer sub-harness for that light was all corroded inside the connector. New problem, all brake lights are fully operational but the brake light out indicator in the cluster comes on intermittently, Off for days then on for half a day then back out.
