SUSP : 5-lug conversion (the all-prelude way)
    Here are the pics of the LCAs:
    Accord on right/ BB6on left.
    BB6 on top.
    Accord on bottom.
      That looks identical!! Shit I should've kept the LCA off the Lude
      Just curious, when are you going to attempt pressing in the Lude bearings on to the Accord knuckles? I'm starting to collect parts at the moment, but if the bearings DO fit the stock knuckles, oh boy...the amount of parts I DON'T need to buy to do this 5-lug conversion...It'd be awesome!!
      Anyways, just curious...Thanks for doing all these researches, much appreciated!!
      Ronald
      |~~~~~~~~~~~~- Project CL1 Euro-R continues -~~~~~~~~~~~~~~|
        They look close but th angles are slightly different. The Positive camber comesfrom the knuckle, rather than the LCA. The accord LCA is longer. The machine shop I go to said that they should fit right in. Also, you will be able to retain the stock axles.
          Well that changes everything!! Definitely good news...OD might fit, but here's what I found while doing a bit of research..
          Accord setup:
          knuckle
          brakes, bearings, etc.
          And here's the BB6 Lude setup:
          knuckle
          brakes, bearings, etc..
          The hole where the bearing sits on the BB6 knuckle looks a lot beefier than ours..My guess is that the whole BB6 front bearing will sink in and fit in there pretty snug..The stock Accord knuckles on the other hand, the hole looks narrower..
          I'm just thinking...If you do press BB6 front bearing into our stock knuckle, wouldn't it stick out on one end? I'm guessing the depth of the bore on our stock knuckles won't "swallow" the whole BB6 bearing if and when we press it in..Any idea/input/opinions/suggestions?
          Oh and another question...On the diagram for the BB6 brake setup...That circlip (Part #22)...Is that to hold the bearing in place?
          Thanks again for everything guys..This thread rocks
          Ronald
            CG*
            CB*
            6th gen knuckles seem to be a viable candidate for knuckle swaps as well (6th gen on top, CB at the bottom). Judging from the brake caliper bracket, the size + geometry all checks out, plus they're more abundant than BB6 knuckles (but that is another thread)... something to consider
            Originally posted by lordoja
              i know its offtopic but 6thgen knuckle may swap over too? any other info on that? i have a parts one near me i could get i might get it and do measurements for another possible 5 lug swap
                Get pics
                  it doesnt look like the bb6 brg will work in the accord knuckle because its a totally different style of bearing, and its held in with a snap ring where as the accord is bolted in. thats what i can tell from those pictures
                    I would so do this if I got another CB7.
                    Raceline USA
                      Originally posted by djcaz_aom View Post
                      I might have found another option on rear hubs that allows you to maintain the stock size rotor. The Type R is slightly smaller.
                      I will keep you posted.
                      type r hubs do not fit
                      not even close
                        Originally posted by gloryaccordy View Post
                        Get pics
                        i have my 6thgen i take pics tomorrow. and i called the guy and he said i could have all the parts i wanted so if it fits im going to get it
                          I was thinking more on the lines of the RSX.
                            what would the going rate for 00 prelude hubs, rotors and brakes for all four sides be, i got a guy who's selling to me cheap, like under 100 dollars cheap, what would you pay
                            1992 Accord EX MT : CB#2
                            DIY OEM amber corners w/reflectors
                              I paid 150 for just the fronts, and they wanted another 100 to 150 for the rears
                                cool, that's about what i was thinking, the guy changed his mind and now wants 450 for everything, i said never mind.
