Rim Cleaning
    Like everyone else said, looks nice. Do you use anything to help prevent brake dust/road grime from clinging on?
    1991 Accord Ex - H22A - Omnipower Coilovers - Greddy SP2
    1993 Civic Dx - D15B7 - T3/T04E - Ported head - Hole in block - May be going F swap
    My Workout Log
    Originally posted by Leung
    Well, I poked the big one in the head with the shovel while shouting at it "hey, you can't sleep here".
      Thanks..Ummm I don't use anything for dust and road grime because I get very minimal grime and dust so I just wipe it off with a microfiber cloth...my dads 745li has 20 inch rims and accumulates tons of break dust, I just just wash off the dust with water and just wipe it clean with a terry cloth...
      KEEP IT NICE, NOT RICE
        i just bout some 16" 5zigen wheels and i can't get the oxidation off! im down down to the metal on the lip. i used grit wet, i tried mean grean, wheel clener, and polish! its very hard to get it off, i think the only way is to sand it down to bare metal and then polish the lip. any suggestions?
          1000 grit!
            ^there is a edit button..
            But I am looking for some answers on that topic also.
            1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
            Originally posted by keepinitclean
            I give it 2 weeks before you sell it.
              Sorry guys i dont know anything aboutsanding rims but you can use a pressure washer....the cheap one! NOT the high pressure one! Maybe you can get some wax and tar remover from Walmart...I saw that there amd maybe that could be the solution
                Everybody Post Before And After Pics!!!
                  looks really good
                    Whoa simple green mixed with wd40 mixed with mother mag polish! Thats a no no n a big chemical fusion going! I would understand going one product at a time and using as i was intended for maybe some scrubbing and washing down after using mean green and wd40! Then after the wheel is cleAn use mothers to polish it up but this whole thread is basicLy polishing!
                    No tryng to offend you for tryng n result was good on your part cus of bravery mixing chemicals but i wouldnt reconmend to anyone till you perfect it or get steps right! Might mess someones wheels up!
                      ohh no offense taken...but wd40 is grease, and simple green is a degreaser....WD-40 would loosen up all the dirt and the simple green would just take out all the grease left over. The polish would then bring on the shine. I see where you are thinking about the no no chemical fusion but once I buffed the wheel some minor scratches came out too...its just a suggestion for wheel cleaning
                        Hey i undersand where your getting at and i see what your tryng to explain! Hey it worked for you and all but they have auto products for this! Theres auto wheel bleach this this works wonders! Removes everything and is clear coat safe! They sell it at your local walmart in the auto cleaning section! Stuff is from5-7 bucks for a big spray bottle! I recomend using purple rush degressor first let it sit for 3 mins to let it do its work get a scrub brush for wheels and scrub em real good rinse them real good then use the wheel bleach re peat same steps as purple rush by then rinse n dry hit it with mothers n bam clean n blinging!
                          Also reconmend using turtle wax wheel cleaner! That stuff actually works great!
                            the best stuff i have used for my stock 91 ex rims is eagle one a to z all wheel cleaner you jest spray it on a cool dry wheel and tire let it foam and after 30 sec hose off with water, then i use meguires cleaner wax on the rim and it looks brand new!!!!!
                              I like all those ideas! I'll try to get em all...
                                Haha start printing these ideas out!
