So I recently bought a 92 accord with an f22b swap and I'm running into a bunch of problems. It idles really weird, I've tried adjusting it but it still runs like crap. Bounces up and down between rpms and then some times it'll die coming to a stop. I know the stock PT6 ecu needs to be changed but it could still run halfway decent. Also there looks like a vacuum line popping out of the transmission it sits right on top but idk where that's suppose to go. I need a bunch of help on this, this is my only car so I need to get this thing running right. Can someone just plz help me and not make me feel like an idiot about it? I'm not dumb to cars just never worked the f22bs or many dohc for that matter. Help!!
f22b dohc swap problems???
I'm thinking that you may not be too familiar with cars. Your symptoms sound like nothing to do with the engine being a DOHC, or an OHC at all.
Start checking for vacuum leaks with a flammable liquid like carb cleaner being sprayed over the intake manifold and throttle body with the car running.
Check plugs, wires, cap and rotor.
Check EGR, PCV valve and O2 sensor also.
Also, F22Bs don't have a perfect timing belt option over here in the US. People either use B18C1 belts or belts from an '80s Caravan with the 2.7L V6. It's possible that the engine just isn't in time.
Start with those and research other possible methods to employ. You also never mentioned check engine lights so I'm assuming you don't have one.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Find out what pin number it corresponds to and you'll have your answer.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
