Saggy shift boot fix
    Okay lets try this again, i got a car with a chopped shifter knob and the boot sags now that i replaced it with a newer shifter. A toyota pickup shift knob will fit nicely and is rather comfortable for those wanting a different one.
    i found a little fix for the leftover sagged out boot that works very well and is dirt cheap if not free like my case.
    this little rubber grommet fits great and keeps the boot in place, as well as being adjustable as it grips the tapered surface of your shifter.
    heres how it looks now
    you can also use a washer like this although this one was slightly too large.
    the only thing you really have to do is adjust the rubber grommet up or down while its in fifth gear to prevent the boot from being too tight and its looking great IMO.
    anyway i know its basic but i figured it could help someone being that those crown royal bags are ugly and some people may like the toyota knob as much as i do.
    BTW any tapered rubber grommet that will fit on the top of the shifter and is slightly larger that the opening at the top of the boot will do the do. i liked this one because it was nice and flexible and the hole in the center was just a tiny bit bigger than the threaded section on the shifter
      ok
      Nice and informative... i will try this once i change my shifter knob
        I used a small zip tie with a washer on top. That worked quite well.
        sold! But here's my build thread for those interested.
        http://www.cb7tuner.com/vbb/showthread.php?t=206864
          http://www.ebay.com/itm/151476804250...;3AMEBIDX%3AIT
            Yeah those are alright but there also nine bucks + where as this was free for me and the rubber grommet you need most likely won't cost you over $2 at someplace with plumming supplies or even the ones for making beer.
              its make a offer...
                this is a hell of an idea and looks like it works perfectly.. this will be something i do on my accord and tsx
