INT: honda Prelude steering wheel conversion on 90-91 cb
    Originally posted by MclovinRR View Post
    it does work if you wire the plug correctly... oh and if your cruise control works...lol
    k, well I had to cut and splice my wiring and use the Prelude clock reel, and my cruise worked before I swapped the wheel and it doesnt now.
      thats very wierd.... as long as the wires are cut and spliced correctly i dont see why it shouldn't work
      DELTA CAM GROUP BUY
      http://www.youtube.com/watch?v=PSbCQuhAnNcla gringa pt.1
      http://www.youtube.com/watch?v=hMz-F2saG_ola gringa pt.2
        just conect the wires by color thats what i did and the cc worked... i think for our cars the cc is the purple ones
        and tanks for the comments on the wheel and i sold the three line wheel to a friend for 50 ha i should of gotten more for it
        from this
          i'll have a look at it. i havent really played around with it since i installed it.
          all i know is one day i tried to use my cruise after i installed the wheel and it didnt work.
            does anyone have pics of wat the back of the wheel looks like after you cut it cuz i think i took alot of the little backing plate is cut off and i filled it with quick steel and cut some more off but still rubs and it gets really stiff does anyone have a pic of it so i can see if i did something write ??
              i didnt cut anything. i just put about 7 1/8 thick washer on mine or as many as it takes for it not to rub. been working great for 2 years now.
              Red Wagon DD - 1993 EX
              http://www.cb7tuner.com/vbb/showthread.php?t=172734
              Gray Wagon Project - 1992 LX
              http://www.cb7tuner.com/vbb/showthread.php?t=166337
                Great DIY article. My big concern, is the Prelude steering wheel smaller in diameter than the factory Accord steering wheel?
                '92 CB7 H22a M2B4
                  I thought the diameter was the same as Accord.
                  Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
                    did you put the washers before or after the clock spring ?
                      just put it before the steering wheel goes in.
                        thanks guys i did the washers thing and it fits perfect thanks guys
                          I want to do this on my 92 but i dont really understand everything i need to do the swap. I know i need a resistor or to remove the bulb and to use washers but thats about it. All i have is the steering wheel. can i make this work?
                          I am aware it is unsafe to remove the airbag.
                              i have 91 ex coupe...i have cc nut no buttons on the wheel just the one on the dash next to the sunroof switch...will my harness still have three wires?
                                If there is no cruise control buttons on the steering wheel and the resume and set buttons are on the dash, all you have to worry about is the horn i think. I wish mine was like that lol.
                                You are going to have extra buttons on the steering wheel that do nothing though. Get Carbon fiber or plastic and shape it to the buttons to block them off. ive seen that done before
