So I have already removed the door panel and put the window back on the two white clips that are attached to the window motor but the problem I am having is that once rolled up when I roll the window down the clips just pop off the glass window and the regulator rolls down leaving the window up. It also seems to have a bit of trouble pushing the window up but not because the motor is weak but the channel that the window runs in is so tight. So my question Is this something that anyone else has experienced and is there an adhesive or something that I need to add to the clips to hold the window?
Also should I lubricate the track that the window travels in with something such as white lithium grease or something? Its pretty frustrating getting it all together and rolling it up then hearing it pop right back out when rolling it down.
Thanks
Thanks
