Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech
Old 02-01-2009, 12:42 PM   #1
bjaccord
CB7tuner Member
bjaccord is cool... so far.
Continuous Problems-Fuel System?
I've had an ongoing problem since September of last year. Here's the story, if you have any ideas let me know, I'm about ready to gut anything related to the fuel system and start over.
Setup-
Walbro 255
RC 750cc
AEM Rail and Regulator
-6AN lines from the pump to the rail
Inline -6AN filter
I got the car on the road last summer at the end of July, built, boosted and tuned, making the numbers in my signature. About a month goes by, I'm at the dragstrip and the car turns off right before my run, no fuel.
So I get the car towed home, me and a buddy test the main relay, its good, I put him in the trunk with a test light, turn the key and he sais we have power, so the pump is bad, right? Wrong, he probed the sending unit wire. We don't figure this out for a long time.
We replace the pump with another walbro, and somehow, while putting the pump assembly back in the tank the filter comes off, leaving the pump un-filtered. As we get it all together, we test it, nothing. So I get in the trunk and test the wires, no power to the pump. (This is where we learn the mistake of my friend who tested it the first time). So from there I get an old ecu and swap it, pump comes to life. My ecu was bad the whole time. So I swap my chip into the other ecu and the car runs great, except I start running out of gas at 1/4 tank. So I park the car and come back to it later, drop the tank and find two things, the filter is gone, and the hose inside the tank has starting coming apart. Theres shit floating all over in the tank from the hose at this point. So we rinse the tank out about a hundred times (Or so it seems), find the filter and get it out. Replaced the hose and filter, made sure nothing was coming apart and put it all back together. Test driving the car it runs like shit, lean as could be, not getting anywhere enough fuel and detonating.
So we pull the fuel filter, rail, regulator, injectors etc. The filter is completely clogged, it's a cleanable filter so I clean the hell out of it, the rail and lines, clean the injectors as much as I can and put it all back together. Still runs like shit, lean and detonating.
This is where the car sits as of right now. I'm not sure if the debris going through the pump ruined it, maybe the injectors are clogged, I have no idea and am tired of taking the tank out of the car....
Anybody know of a way to test this shit out without just replacing it?
I know I can send the injectors out to be cleaned, but I feel like the pump is messed up, but is there a way to test it? I have a fuel pressure guage on it, and it makes good pressure, but I'm thinking that somehow it can't keep up with the volume it needs.
Like a garden hose barely turned on, if you kink it it will build up pressure, but open it up and al of sudden theres no water.
Just looking for some feedback and ideas before I spend more money.
L8r all
__________________
Turbo H23a3 build has begun
01-01-2019
bjaccord is offline   Reply With Quote
Old 02-01-2009, 03:48 PM   #2
excalibur02
Wanna be JDM whore
Location: north new jersey Owns: Turbo cb6 & NA cb7 I'm: NJs 5-lug King ;-0
excalibur02 seems to have made some friends!
Send a message via AIM to excalibur02
hey brady!
maybe when the 2nd time putting the pump in (when the filter fell) something went to the lines and clogged the stock hard lines.
See if you can maybe get a bucket of some sort. Have the pump in that bucket with gas of course. See if it sends enough gas to your injectors.
If anything since your built and boosted. I would suggest a custom Stainless Steel line from the pump to your fuel rail. My friend did this to his civic and he spent about $90.
good luck!
__________________
Instagram username MAURO02
If my pictures do not work and you see ****.com replace it with m1xe.com
excalibur02 is offline   Reply With Quote
Old 02-01-2009, 06:55 PM   #3
bjaccord
CB7tuner Member
I already have braided lines from front to back, and we primed the pump several times into a cup and all seemed fine. My thing is with some restriction on the pump, maybe the rotors inside the pump were damaged by the debris and it can't provide the volume and pressure now.
I really don't know, it doesn't make much sense to me.
L8r
__________________
01-01-2019
Old 02-01-2009, 07:08 PM   #4
TypeG
Moderator
TypeG is very helpful TypeG is very helpful
maybe you could try and put the old pump back on? later.
__________________
Avoiding dirt at all costs
TypeG is offline   Reply With Quote
Old 02-02-2009, 08:38 AM   #5
HondaFan81
Honda Enthusiast
HondaFan81 seems to have made some friends! HondaFan81 seems to have made some friends!
How confident are you of the injectors being clean? I would remove and replace the tiny filters in them with new or clean them very well. Also, inspect the original filters in them, for any holes blown through the screens (then you have possibly bad injectors).
Did you clean the fuel rail, inspect fuel pressure regulator as well? Or atleast remove the line to the fuel rail and the return from fuel psi regulator, run water or fuel through it to make sure it flows well?
HondaFan81 is offline   Reply With Quote
Old 02-02-2009, 04:49 PM   #6
bjaccord
CB7tuner Member
Everything has been taken apart and claned as best I can. I sent the injectors out to be cleaned, flowed and balanced so we'll see what comes back from them.
I'm going to switch back to the old walbro and try it again. I was talking to the guy who does my injectors (www.codymotorsports.com) He's local to me and he has had alot of customers with bad walbro pumps, and sent me to this link http://www.turbobuick.com/forums/gen...o-failure.html
interesting stuff, fake walbro's....
I'll keep you guys posted, and keep the ideas coming...
I read the plugs today as well, all cylinders lean, so I'm thinking it may be the pump, odds of all injectors being bad seems unlikely to me.
L8r
__________________
01-01-2019
Old 02-18-2009, 10:25 AM   #7
turbo90accord
Super Moderator
turbo90accord is cool... so far.
what filter are you using for the sock filter on the pump?
__________________
member ride thread
DIVULGE MOTORSPORTS
turbo90accord is offline   Reply With Quote
Old 02-21-2009, 09:09 AM   #8
bjaccord
CB7tuner Member
The one that came with th Walbro pump.
The article I posted above talks about fake walbros flooding the market, so I'm going to put my 4 year old walbro back in this weekend and give it another try, I think the new one was a fake.....
__________________
01-01-2019
Old 02-21-2009, 11:46 AM   #9
turbo90accord
Super Moderator
i had issues wiuth my walbro at first because the filter that came with the pump kept getting pushed up and causing starvation problems. i replaced mine with an oem filter and works perfect now.
__________________
member ride thread
DIVULGE MOTORSPORTS
Old 02-21-2009, 01:09 PM   #10
dbsharp
CB7tuner Member
dbsharp is cool... so far.
Does your 255 walbro make a hum when you have the car running. My "walbro 255" dosent and I was told that they are normally audible. I also am having another fueling issue, my afrs are just so inconsistent its ridiculous. I think the pump I have is fake.
__________________
spin city
dbsharp is offline   Reply With Quote
Old 02-21-2009, 02:56 PM   #11
turbo90accord
Super Moderator
yes mine makes a hum when being primed as well as when running.
__________________
member ride thread
DIVULGE MOTORSPORTS
Old 02-21-2009, 05:02 PM   #12
wed3k
Contributing Member
wed3k seems to have made some friends! wed3k seems to have made some friends!
Send a message via AIM to wed3k
use a multimeter when testing voltage because you wont know if you are getting CORRECT voltage instead of just plain voltage.
__________________
I <3 G60.
wed3k is offline   Reply With Quote
Old 03-03-2009, 05:19 PM   #13
excalibur02
Wanna be JDM whore
Hope you figured this out brady
__________________
Old 03-04-2009, 11:24 AM   #14
HondaFan81
Honda Enthusiast
Quote:
I have an authentic Walbro 255 lph, it is definitely audible when priming (key position II) or when in "RUN"/driving mode. It works flawlessly so far (400 miles).
I too agree that if all cylinders are running lean, I would suspect the fuel pump of fuel filter clogged. It would take a lot of debris to clogg the filter though, never seen it happen yet.
I think Brady is on the right track with these fake Walbros, I heard about that too when I was purchasing mine. I know authentic ones are $100.
Old 03-04-2009, 11:26 AM   #15
HondaFan81
Honda Enthusiast
Did you use both plastic adapters that came with it before installing the filter? That is what I did, haven't had any issues so far (400 miles). Starts up great everytime, less cranks than stock actually (mostly due to 12:1 compression, but ignition & fuel are in check as well).
Old 03-04-2009, 07:31 PM   #16
turbo90accord
Super Moderator
im not really sure what plastic adaptors your talking about.
__________________
member ride thread
DIVULGE MOTORSPORTS
Old 03-05-2009, 07:31 AM   #17
bjaccord
CB7tuner Member
the pumps com with a little spacer that attaches to the pump, then the filter attaches to it.
__________________
01-01-2019
Old 03-17-2009, 06:40 AM   #18
bjaccord
CB7tuner Member
Got the specs back from the injectors, keep in mind these ar RC 750cc injectors:
1:195cc
2:230cc
3:680cc
4:290cc
Had all new filter baskets put in, cleaned and re-flow tested, there all flowing about 770cc now, so I'll put them back in the car this weekend and try it again.
L8r all
__________________
01-01-2019
