Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech
Old 02-08-2009, 09:45 PM   #1
whitecoupe91
whitecoupe91 is cool... so far.
H22/H23 hybrid...
H22 block with an H23 head. It should have higher compression right? Would the piston to valve clearance be fine if I used the H23 crank. Has any one ever tried this setup? If your going to ask why, I have an extra H22 complete block and a complete H23 that needs new rings. So why not try it!!!!
Honda-mans best friend!
who said it was a dog?
PINOY PRIDE
OHIO CB7's
whitecoupe91 is offline   Reply With Quote
Old 02-08-2009, 10:08 PM   #2
d112crzy
d112crzy seems to have made some friends!
Yes, compression would be higher than that of an H22 due to the H23 head having a smaller combustion chamber(50cc vs 53.5cc) You' have to measure the valve clearance to be sure, I think you'll be alright.
With a complete H22 bottom end, you're compression would jump to a tad over 11.1:1. This would essentially make it an non vtec h22, or a high compression and destroked h23. I like non vtec h22 personally, lol. H23 crank/H23 rods/H22 pistons would bump up the compression to 12.4:1.
That would be if you were using JDM H22A pistons(non type s). If you were to use USDM H22 pistons, the compression would drop about .8 of a point from either combo.
Either combo would make for a killer H23 build. Personally, I'd go for the H23 crank/rod combo. I'd use a thicker headgasket to bring the compression to an even 12:1 and you'd also give you more p2v clearance and would also give you room to upgrade to bigger cams in the future.
Do it
d112crzy is offline   Reply With Quote
Old 02-08-2009, 10:16 PM   #3
whitecoupe91
Cool. This is for my lady's lude! I have jdm h22a pistons. That sounds great about the compression. I think I will go the h23 crank and rods, h22 pistons. With the normal I-H-E mods should be a fun car.
PINOY PRIDE
OHIO CB7's
Old 02-08-2009, 10:18 PM   #4
whitecoupe91
Being stock internals, kind of, do you think it would run fine with the stock ecu or should a chipped ecu be in order?
PINOY PRIDE
OHIO CB7's
Old 02-08-2009, 10:29 PM   #5
d112crzy
A tuned(chipped) ecu would DEFINITELY be in order.
Old 02-09-2009, 02:32 AM   #6
visualpoet
visualpoet seems to have made some friends! visualpoet seems to have made some friends!
Send a message via AIM to visualpoet Send a message via MSN to visualpoet Send a message via Yahoo to visualpoet
CORY!!!!! Welcome back brother! Glad to see you're still alive and well out there in z-ville!
visualpoet is offline   Reply With Quote
Old 02-09-2009, 06:53 AM   #7
whitecoupe91
What's happening John! Yeah we're all still doing great! I'll have to post pics of my lady's lude, it's definently girlie lol!!
PINOY PRIDE
OHIO CB7's
Old 02-09-2009, 11:30 AM   #8
wed3k
wed3k seems to have made some friends! wed3k seems to have made some friends!
Send a message via AIM to wed3k
i love you.
I <3 G60.
wed3k is offline   Reply With Quote
Old 02-10-2009, 05:55 PM   #9
bjaccord
bjaccord is cool... so far.
I love my non vtec h22. Numbers are in my sig.
L8r
Turbo H23a3 build has begun
01-01-2019
bjaccord is offline   Reply With Quote
