Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Forced Induction
Old 07-11-2009, 12:00 AM   #1
bkmc24
bkmc24 is cool... so far.
Intercooler Dimensions
What are some common dimensions run without cutting the front bumper. I want it to fit behind the plastic and literally want everything to look stock from the outside with a little IC peeking through if you know what to look for.
bkmc24 is offline   Reply With Quote
Old 07-12-2009, 12:30 AM   #2
simha1
simha1 is cool... so far.
whats good man, it all depends on your bumper. i cut mine but it stll look like it did before. are you talking something kindlike this
before intercooler
after intercooler
length 28" height 7" and thickness 3"
simha1 is offline   Reply With Quote
Old 07-12-2009, 12:47 AM   #3
bkmc24
Somewhat. I dont want to have to cut anything. I want it to fit in behind everything. Im debating using my supra SMIC as a makeshift FMIC off to the side, or buy a new one.
Old 07-12-2009, 12:50 AM   #4
noobcake
noobcake seems to have made some friends!
i highly doubt your going to fit ANY intercooler in your bumper without cutting.
look at chessboxers setup. he hacked his bumper but you can barley tell.
then just paint it black.
noobcake is offline   Reply With Quote
Old 07-12-2009, 12:52 AM   #5
WiKKeDV16
Mr.Influential.
WiKKeDV16 is cool... so far.
Send a message via AIM to WiKKeDV16
here is the best example i can give u..
stock srt4 fmic rotated..
this setup works only if u dont have a/c as the intercooler outlets are backdoor(go into the engine bay) vs out the sides of the I/C
the bumper was hacked.. but that was because it was a 91 bumper.. then the bumper was switched to a 93.. and the cross beams of the bumper were left intact.. no "hacking"
here is the same car.. with a BIG srt4 fmic.. with the 93 bumper unmolested
it was trimmed.. to clear.. but as you can see the bumper looks stock
Praise The Lowered...
WiKKeDV16 is offline   Reply With Quote
Old 07-12-2009, 12:55 AM   #6
WiKKeDV16
Mr.Influential.
neglect the fact that were working on it.. lol..
another view
Old 07-12-2009, 12:56 AM   #7
C91BLX7
C91BLX7 is very helpful C91BLX7 is very helpful C91BLX7 is very helpful
mmm doughnuts
wat?
C91BLX7 is offline   Reply With Quote
Old 07-13-2009, 07:32 PM   #8
bkmc24
Cool, well thanks for the insight. IG ill have to start looking into a size that will require minimum cutting.
Old 07-31-2009, 11:00 AM   #9
h22sparkle
h22sparkle may have said something they shouldn't have...
I told you an srt4 intercooler is best. Well the stock fittiment if you dont want to cut little bit of th bumper and have it lookin stock.
h22sparkle is offline   Reply With Quote
Old 07-31-2009, 11:08 AM   #10
guitarplayer825
guitarplayer825 is cool... so far.
Send a message via AIM to guitarplayer825
So there's more space behind a 9293 than there is behind a 9091?
Underground.Society
Originally Posted by Deevergote
If it doesn't really matter... shut the fuck up and let it be.
guitarplayer825 is offline   Reply With Quote
Old 07-31-2009, 03:09 PM   #11
drummersteve7
Boost Junkie Rehab!
drummersteve7 seems to have made some friends!
did some measuring...cutting the bumper later....
24.5" x 11.75" x 3"
have to cut to be effective, good luck!
MadLab Racing
Southern Maryland
drummersteve7 is offline   Reply With Quote
Old 07-31-2009, 07:53 PM   #12
bkmc24
Thanks. I am going to have to cut, and bought a fmic lol.
Will be test fitting and installing a lot this weekend. Almost ready for booooost
Old 07-31-2009, 09:50 PM   #13
kamaccord
kamaccord is cool... so far.
http://precisionturbo.net/Wc21126d5f695d.htm
600HP" 1990 ACCORD LX COUPE COMING SOON
CLICK HERE TO VIEW MY 1990 CB7
kamaccord is offline   Reply With Quote
Old 08-02-2009, 01:42 PM   #14
bkmc24
When you put the IC in, what did you do with the PS cooler?
Old 08-10-2009, 02:25 AM   #15
drummersteve7
Boost Junkie Rehab!
lose it. P/S is for nancies!
MadLab Racing
Southern Maryland
Old 08-10-2009, 08:21 PM   #16
bjaccord
bjaccord is cool... so far.
From what I remember its a 20x14x2.5" core, but not 100% sure. (I've had it for along time) It will support about 400whp with no problems, and no trimming of the front bumper (Just a tiny bit on the reinforcement bar). It fit with a/c as well when I had it.
L8r
Turbo H23a3 build has begun
01-01-2019
bjaccord is offline   Reply With Quote
Old 08-10-2009, 09:15 PM   #17
drummersteve7
Boost Junkie Rehab!
24.5" x 11.75" x 3"
with this FMIC I had to trim the upper support just by 2" cause of where I mounted it.
and now a pic with it on the car:
decided to paint it black:
good luck!
MadLab Racing
Southern Maryland
