K24/k20 Cb7
    Old engine out.. In the process of cleaning up the bay. Gonna remove as many unnecessary wires and parts possible. Making progress.
      So somehow all of my pics disappeared no biggie, half of the parts I started with were traded for something different anyway. So here is the list of what's here to stay and being put together currently.
      Motor is at the machine shop getting cleaned, bored, resurfaced, etc. Aiming for this swap to be done by the end of next month.. Any longer and I'll be damn near $15k lol.
      Looks like I have to find another way to post pictures other than photobucket. In the meantime, here is the confirmed list of parts I'm using. We'll save pics until the motor is actually in the bay.
      CYLINDER HEAD
      - K20Z1 PRB Head
      - 4 Piston Racing RR4 Camshafts
      - Skunk2 Ultra Street Intake Manifold (Ported & Polished)
      - S90 76mm TB
      - Ferrea 5000 Flat Faced Valves
      - Supertech Valvespring & Titanium Retainers
      - Adjustable Cam Gears
      - K Tuned 4-2-1 K Swap Header
      BLOCK
      - K24A2 Acura TSX Block
      - Arias Pistons 88mm 12.5:1 CR
      - K1 Technologies Lightweight I Beam Rods
      - PRB Type S Oil Pump
      - ARP Rod Bolts
      - ACL Race Bearings
      TRANSMISSION
      - K20Z3 SI Transmission Casing
      - K20A2 Type S Transmission Internals
      - K24Z3 OEM LSD
      - XTD Stage 3 Clutch & Lightweight Flywheel
      MISC
      - Innovative CB K Swap Mounts 60A
      - CX Racing 3" Triple Core Halfsized Radiator
      - PRB ECU w/ KPro V4
      - Yonaka RSX Type S Axles
      - Trubendz 2.5" CB7 Exhaust Piping
      - Vibrant Ultra Quiet Resonator & 2.5" Muffler
      - RDX Fuel Injectors
        Hey, which machine shop are you using? I'm testing out Scott's in Fayetteville, but I don't know if I want to give them a block.
        YouTube Clicky!!
          I used Superior Parts & Machine on Moreland Ave. Good prices and great, quick service.
            rsx axles work?
            COUPE K24
              Haven't tried them yet but they should work by swapping the inners. Also heard that TSX axles with the Accord outers work.
                Just go on RockAuto.com and check axle lengths and compare inner/outer designs and spline counts.
                  im using the prelude sh axles.
                  COUPE K24
                    There's also Dover by Summit, and Joes in Decatur. I've never heard of Superior.. might have to stop by there
                      Yeah I reached out to Dover but they only do cylinder heads. Superior is really good and also Will's Machine Shop in Chamblee.
                        Got motor back from machine shop, ended up going with Will's Machine and it turned out great! Now time to put everything together..
                        Red Powder Coated Valve Cover (came out much better than expected)
                        Cylinder head cleaned and resurfaced..
                        Block bored and honed to 88mm now..
                        Crank balanced and polished..
                          Pics no work
                          YouTube Clicky!!
                            Sorry, try again. Been having a hard time posting pictures since photobucket switched to this 500 thing.
                              Finally have some free time to get my pictures uploaded again. While the engine is being built, I'm gonna try and do a little paint work to the engine bay. Setting a timeline to have the car up and running by the end of August.
                              Mounts..
                              Valves..
                              Springs & Retainers..
                              Camshafts..
                              Throttle Body..
                              Intake Manifold..
                              Header..
                              Pistons..
                              Rods..
                              Transmission..
                              KPro..
                              Radiator..
                              Axles..
                              Exhaust Piping..
                              Engine bay..
                              Can't wait to have this thing on the highway!
                                the more i see that budget k swap header the more it looks like that will be the one to work.
                                COUPE K24
