Drag wheel options?
    Drag wheel options?
    Can a 13" wheel fit around the brakes?
    Also if anyone wants to post up what they run just for comparison sake
    13 inch wheel will not fit, I tried some 13x10 Dc2 integra slicks. They were weld drag wheels, and it did not clear the brake caliper. I don't know about any other wheel.
    MRThttp://www.cb7tuner.com/vbb/showthread.php?t=84102 93se h22/t2t4
      13" wouldn't really be that great for drag anyway. 14" and 15" are more common/cheaper slick sizes, and smaller wheels just mean the tire weighs more (if keeping the same outer diameter).
        A wide, lightweight 15" wheel is pretty much your best bet. Address further traction issues with suspension upgrades and modulated power delivery (feathering the clutch, or boost by gear ECU tuning.)
          There are many more options for 13's than 14's. The point is to have the most sidewall possible
          Both these cars are on 13's and run damn good on them
            Pretty sure the smallest you can run is a 14 due to the brake caliper.
              Indeed, but 13s will not fit on your car... so advice was given taking that fact into consideration.
              Good luck with your project.
                Alright thanks guys, just another cb7 limitation. Shooting for 10's next year
                  14's fit, I think you could get 13's to fit with a smaller caliper.
                  It looks like ek civics can run 13's, so use whatever caliper they run on the front. Iirc, the caliper on the front of my cb7 and dc2 are the same, so maybe the em1/ek coupe has the same size, maybe that particular wheel is thin enough to fit.
                  sold! But here's my build thread for those interested.
                  http://www.cb7tuner.com/vbb/showthread.php?t=206864
                    Found some 15x8 circle track wheels to fit. Now to make some custom fenders
                      Just so you're aware. Those wheels have a 45 degree conical seat. Stock is 60 degrees.
                        Good call. I hadn't checked that yet, still in mock up stage
                          im new to this but i want to know what parts of a F23A1 wil fit mi F22A6
                            Then why did you invade a completely off-topic thread in which to ask that question?
                              [/URL]
                              Here is how it looks. 15x8, 5 inch backspace. 24.5x8.5 MH slick
