Idle and A/C
    Idle and A/C
    I recently adjusted my idle and cleaned my FITV.
    This may be a dumb question - when the air conditioner is turned on, is the idle RPM supposed to rise? Rises from 750 to about 1100.
    I've never had this happen before I cleaned the FITV. I don't know if it's cause it's working correctly now or if something is wrong.
    FYI I also noticed deposits in the coolant lines and I need to flush those out - that may be the problem.
    tried cleaning the iacv?
    I <3 G60.
      It should only rise to about 800 - 900, not 1100.
        I guess I tested it (continuity and resistance are good) but never cleaned it. Will do.
        I think I have a problem with my A/C clutch which may be related.
        I get an occasional squeaking noise when the car is idling and the A/C is OFF. If I turn on the A/C - the noise stops. No change if I just turn on the blower fan. It seems to be coming the from pulley itself rather than the belt. I haven't figured this out yet.
        Thanks for your help guys.
        Beyond all this technical stuff, this is an easy question that anyone can answer (just to get more of a sample): when you turn on the A/C, how much does your idle go up?
