Wondering if I could get some advice from people who've been there. What do you think I should do? What makes sense here?
Currently have: 91 Lx sedan 5 speed.
I'd like: a wagon (5 speed preferred) for DD, but better looking than current car.
I'm thinking of swapping parts into a wagon. I have fairly good mechanical skills, no body skills but I could learn I'm sure...
The facts:
- I have 170k on my car, replaced with new (rebuilt) cylinder head 10k ago.
- Engine runs fine, not the best compression numbers, but no big issue.
- My car is fairly beat up. Many dents, rust in wheel wells, paint is dry and dead. I'll try and take pictures if you guys are interested.
- The clutch is on the way out and needs to be replaced soon
- The trans is OK - shifting isn't amazing, but good enough, some grinding into 3rd. (got better after adjusting cables but not by much)
- The brakes and rotors are due for a change.
- The passenger CV is going out
- I tore out A/C a while ago and don't really miss it that much, but some other buyer might
- The shocks aren't in great shape, or I have a possible broken/weak motor mount, or both. Something going clunk.
- I removed the seats (except driver, obviously) for more space and storage room. I do handyman work, a wagon would be a better choice. FWIW, the seats are in storage and are pretty clean. Not a big deal to stick them back in, but it'd probably take a little time at least. Blue interior. White exterior.
Interior is pretty clean, actually.
- The tires have a little life left.
Based on the above, I figure, even with the seats and interior put back in, new clutch and brakes and all that, my car still isn't worth much because the body is rough. And that's a fair amount of work and some money too, don't know how worth it that all is. The car would work for me but wouldn't be worth much even with new parts...at least I can't imagine it's worth much.
Instead of doing the clutch and all, I'm thinking, how about buy a wagon with a blown trans or something like that?
Spend the time and effort on brakes, axles, clutch, maybe new mounts, maybe even fixing that 3rd gear synchro, all in a new wagon shell. Something with a straight body. Ideally a solid color paint that I can touch up easily enough.
So what would make the most sense, cost and effort wise? Fix my sedan and sell it off as a whole car? What would my car be worth, anyway...not much I expect.
Or keep it around for parts? Buy a wagon with say, a blown auto trans/really high miles/some sort of issue. Use the parts from my 5 speed sedan and swap it into the wagon. Maybe swap engine if there's an issue with the one in the wagon, having the rebuilt head in mine is nice I suppose. Do the clutch work with it pulled from the car for ease perhaps. Replace axles and do brakes all at once. Motor mounts if I need them (I know about the 5spd/auto mount issue), and, rear main, etc. Whatever parts are left over from my sedan sell as parts and then scrap. Come out with a decent DD wagon.
What scenario sounds like it'd make sense to you guys?
I partially just want to have a project to work on, I almost want to do the clutch for fun/learning but I want to be at least a little bit practical about it. Looking to save money in the end over just buying a 'good to go' wagon with my labor.
The facts:
