I see the diy on here for our ps pump seal rebuild but there are no pics. I am wondering if 94-97 accord is the same as ours. I see video tutorials on that and some other years and different honda models.
Power Steering Pump Rebuild. Is 94-97 tutorial the same?
The 94 pump (looked at the exploded view on www.hondaautomotiveparts.com) looks like it may be a vane pump instead of the gear pump that is used on the 90 - 93. The website exploded view shows all the parts. Pretty much just take it apart, clean everything, and reassemble using the new seals. If I remember correctly, the pulley nut is left handed.
Last edited by Fleetw00d; 11-03-2019, 11:03 PM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostThe 94 pump (looked at the exploded view on www.hondaautomotiveparts.com) looks like it may be a vane pump instead of the gear pump that is used on the 90 - 93. The website exploded view shows all the parts. Pretty much just take it apart, clean everything, and reassemble using the new seals. If I remember correctly, the pulley nut is left handed.
Only spring is item 5. Make sure you keep track of the orientation of the gears and bearings and that you put them back in the same orientation. Be careful installing the cover (item 3) with the new seal (item 19) so that the shoulder on the shaft doesn't turn the seal inside-out. It helps if you clean the exterior as best you can before disassembling it.Last edited by Fleetw00d; 11-04-2019, 06:55 PM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by zedjr10 View PostAll done and ps pump like new it seems. Thanks
Just kidding Good job!90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
