when i first start up my car on real cold days to warm it up my power steering pump makes a noise and i dont know what it is it gets kinda loud sometimes too because i can hear it from inside my house does anyone know what it could be?
power steering noise
Do you have power steering fluid in your reservoir? Is it a moaning sound?
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
It's called cavitation. The noise you're hearing is air being sucked into the pump from somewhere. check for low oil or leaks if not that. it could be bearing noise from the pump. I believe I saw a good writeup on a pump rebuild. If you have the time it can save you mucho $$$. The kit sells for about $20. from autozone and did not look that hard to do.
Not sure if he has an h22a in his car running the stock accord pump with his setup. Not really sure I was guessing that on his sn but didnt want to jump to conclusions. But if thats the case the high pressure line is prob being restricted with the accord hood hittin it (Mine did that with h22 and stock accord ps pump) But give us a lil more info. That should help out.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
Both pumps are the same to my knowledge. MY pump didnt make any noise when I had the a6. Or no noise audible enough to hear in the cabin.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
