but the lug pattern is the same exact thing. right? some of the older mustangs have the 4x114.3 lug pattern don't they?
SUSP: Front 5-lug Conversion
So wait
Will the Odyssey hub bolt up into the Accord bearing + knuckle?
What I'm getting at is, do we really need the Odyssey knuckles?
They have the same axle splines & diameter. I wouldn't be surprised if the hub to knuckle bolt pattern was the same as well. Only issue would be calipers- but you can get the wagon/Legend calipers + mounts to fit on our knuckles...
Originally posted by lordojaim with you on that one bro! aint nothing beat free food and drinks any day of the week, even if its at a funeral
- no the odyssey bearing does NOT fit in the accord knuckle i tryed
- odyssey spindle opening is bigger than the accord. and the accord opening also has a lip in the opening
- the odyssey hub will NOT fit in the accord bearing
the only way i could see the odyssey hub fit into the accord bearing would be to have it machined to fit
you will need the odyssey knuckles
the accord calipers will work but you will need the t25 caliper bracket
Keep in mind that I don't have a 4th gen Accord, I have a 5th gen. I think you can use a 5th gen V6 knuckle or 5th gen wagon knuckle instead of an Odyssey knuckle. I think I read somewhere that the wagon/V6 bearing may be the same as the Odyssey bearing. None of this has been verified though. I just went the easy route and used the complete Odyssey knuckle (knuckle, hub, and bearing).Last edited by Bird333; 09-30-2008, 11:12 AM.
Originally posted by kc8enb07 View Postcan anyone explain the difference in the Type SH and base prelude knuckles?
Sorry for this revival, but I did the ROH conversion with CL hubs, accord bearings, prelude vtec/accord v6/accord wagon rotors and calipers...the 11.1" rotors.
I can get odyssey knuckles, hubs, and bearings, and my current calipers and brackets will bolt up to this correct?There are no black and white suspension answers!!!!!!!!!!!
does'nt the hub from the Acura RL fit the accord bearing? read something like that on mycb7.com, wouldn't that be faster, cheaper too? i was kinda bummed that i found that out few days after i got new rotors and bearings because i could of just gotten RL rotors and buy new hub with it
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Originally posted by JaberCB7 View Postdoes'nt the hub from the Acura RL fit the accord bearing? read something like that on mycb7.com, wouldn't that be faster, cheaper too? i was kinda bummed that i found that out few days after i got new rotors and bearings because i could of just gotten RL rotors and buy new hub with it
