Door panel fabric, replacement or other....
spray both surfaces with the adhesive and let it sit and get tacky. Then you push them together. That is how that glue works; you can't just spray it on and stick it.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
I have successfully reattached the original fabric with 3M heavy duty spray adhesive. The other option is to find a good set of the SE leather inserts on the stamped steel form. I had a stained set and was able to paint the vinyl a contrasting color to hide the stains. You can see the results in my MRT.Last edited by Fleetw00d; 08-22-2014, 03:24 AM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Yes. It's kind of a pain to do, too. There are a few screws that hold it in as well as two or three large clips (depending on whether you have a coupe or sedan). The clips are what are slightly difficult.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
The fabric along the bottom of my passenger door started peeling off. I used a hot glue gun and slowly reapplied it with a generous amount of glue. It's not a high traffic area like yours might be, but it's in great shape still. Door gets opened often since it's where my daughters car seat it, and is holding up. Might be worth a try too.
Originally posted by Scolirk View PostThe fabric along the bottom of my passenger door started peeling off. I used a hot glue gun and slowly reapplied it with a generous amount of glue. It's not a high traffic area like yours might be, but it's in great shape still. Door gets opened often since it's where my daughters car seat it, and is holding up. Might be worth a try too.
Originally posted by I'm A Yunginn' View PostI'll try this out because I have to take off my door panel for my window regulator anyways.. Thanks for the info.
