Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Forced Induction
Old 12-05-2009, 01:35 PM   #1
dbsharp
dbsharp is cool... so far.
DBSharp's Turbo build
This is a pretty low budget build I put together. I have spent right under $800 to convert my car from NA to boosted.
Parts I got for free from Errol (yardiexd40): This stuff was part of his old setup. His new setup is going to be bad ass.
Holset HY35W type-D turbo
JDM FMIC
Tail Knock off wastegate
Waste gate dump tube parts
Front torque mount for a suburu.
Parts that I am designing/fabricating for this build:
Ram horn turbo manifold
Downpipe
BOV mount tube
Front motormount brackets
Turbo braces
Wastegate dump tube
Parts I bought, not including all the minor BS:
Turbosmart BOV. Got this for $40!
2.5" intercooler Charge pipes and couplers
Down pipe parts
Weirtech flanges for the manifold
K&N filter
I expect this to make 250 to 300 WHP once it is done. I have dsm 450cc injectors and a somewhat small intercooler. If I want to get more power out of this setup later, I could upgrade these parts and crank up the boost! Of course I wont do this unless I get the $$ to build a motor too.
spin city
dbsharp is offline   Reply With Quote
Old 12-05-2009, 02:03 PM   #2
twokexlv6coupe
twokexlv6coupe is cool... so far.
Send a message via AIM to twokexlv6coupe
niioooceeeee
what's the red machine in the first pic? can't be a mandrel bender, since your doing pie cuts
and did you already make that ram horn mani? i might be interested in one of them suckas, if u decide to sell some
BB2F22-T3super60:250hp/275lb-ft @10psi
twokexlv6coupe is offline   Reply With Quote
Old 12-05-2009, 02:45 PM   #3
c mak
c mak is cool... so far.
Nice work Dan!!!
I wish i could do some of that work you do!! The mani looks awesome. Can't wait to see the final project pics! Makes me want to go turbo again, damn it!!!! LOL
97 Yamaha YZF600R
Vouches: wagalude/sleepycb7/accordexr33/yeamans17/heylookitsdylan/tommi/JDMH22ACB7/smokeeey420/sackingz123/
IDriveALude/Losiracer2/626cb7
c mak is offline   Reply With Quote
Old 12-05-2009, 06:47 PM   #4
dbsharp
thanks for the compliments.
The manifold will turn out nice once its done, right now it still has a couple pin hole leaks in it. I am going to give it to a buddy of mine who is going to go back over the manifold with a tig welder. I have A LOT of hours into the manifold so far, I'm not sure It would be worth my time to make them to sell them.
spin city
Old 12-06-2009, 09:45 AM   #5
drummersteve7
Boost Junkie Rehab!
drummersteve7 seems to have made some friends!
dude. your car pulled on the h22 and boosted ford.
now your gunna boost!
I fuckin love you man!
great work. nice to see your doin it yourself.
ETA?
MadLab Racing
Southern Maryland
drummersteve7 is offline   Reply With Quote
Old 12-06-2009, 01:42 PM   #6
weirtech
weirtech is cool... so far.
i'd try to eliminate most of those couplers on the charge pipe.
weirtech is offline   Reply With Quote
Old 12-06-2009, 09:35 PM   #7
dbsharp
I don't own a tig welder. If i did I would only have a couple of them and would have welded up the rest. All of the pipe is flared at the end, so I don't foresee any issues with the couplings.
Oh. By the way, do you recognize the flanges on the manifold? they are all weirtech flanges. I was going to call in a favor and get some cnc lazer cut by a friend. I even had the flanges drawn up and dimensioned in autocad. One reason I didn't was because of all of the dimensions that are necessary for the head flange. I would rather just pay you for them than to use up the favor. Who knows what part I may need cut out in the future.
ETA? I have to find a circlip and seal for the compressor housing on my hy-35 before it will be together. I am waiting on a reply from gpopshop. Maybe I can get them there.
spin city
Old 12-11-2009, 10:07 AM   #8
Sobeman81
Sobeman81 may have said something they shouldn't have...
Send a message via AIM to Sobeman81 Send a message via Yahoo to Sobeman81
It's a horizontal band saw. Perfect for cutting long lengths of pipe.
Sobeman81 is offline   Reply With Quote
Old 12-11-2009, 10:16 AM   #9
h22sparkle
h22sparkle may have said something they shouldn't have...
did you make good clearance with the crossmember with that manifold?
h22sparkle is offline   Reply With Quote
Old 12-12-2009, 12:30 AM   #10
dbsharp
I designed the manifold to fit the turbo I have into the space I have available. It clears the crossmember. I did design it to be used with the traction bar I plan on making. There isn't as much room for the downpipe as I would like, but with a traction bar there will be more room.
I am using the stock radiator and one of the fans. The other fan is going to be a pusher that sits between the intercooler and radiator.
I only have two pieces left to make. The turbo brace and the waste gate dump tube.
I get my last part early next week, so this should be together sometime next week! I want to get the wideband working good before I go beating on it much.
spin city
Old 12-12-2009, 09:09 AM   #11
gdout90accord
gdout90accord is cool... so far.
Send a message via AIM to gdout90accord
manifold looks sick bro, i wish i got a welder.
gdout90accord is offline   Reply With Quote
Old 12-12-2009, 09:23 AM   #12
dbsharp
I don't own one. I borrowed a friends. Now I just need to make some friends with tig welders.
spin city
Old 12-12-2009, 08:26 PM   #13
dbsharp
Every part is fabbed up. I am just waiting on my last part to come in so I can bolt it all together!
spin city
Old 12-13-2009, 02:00 AM   #14
chessboxer
Moderator/Accord of the Month: May 2007
chessboxer seems to have made some friends!
Send a message via AIM to chessboxer
Great work!
chessboxer is offline   Reply With Quote
Old 12-13-2009, 10:00 PM   #15
dbsharp
I updated the first post with new pics.
spin city
Old 12-13-2009, 10:10 PM   #16
drummersteve7
Boost Junkie Rehab!
nice danny, wish I had access to welders.
thinking I might get one before I move on to my full build.
gunna wanna do my own exhaust.
MadLab Racing
Southern Maryland
Old 12-13-2009, 10:27 PM   #17
dbsharp
go for it man!
spin city
Old 12-17-2009, 02:52 PM   #18
dbsharp
I returned my distributor kings dizzy (cam sensor code) and they sent me a brand new one, but it was the wrong part. I would have this car running right now if it wasnt for that. I will have it running as soon as the new one comes in! I think I fixed the wideband too, so I will be able to tune it as soon as it gets running!
spin city
Old 12-20-2009, 05:08 PM   #19
dbsharp
This bitch rolls out now! Spins through first very quickly, and spins in the powerband of second!
According to data logging, I am using every bit of these 450cc injectors, they are just big enough! I haven't even had to hardly touch the basemap I made for my car, afr's are pretty much already where I wanted them to be. I am going to add in some more ignition and see how this motor likes it!
Now to the bad...
The car smokes, bad, but only after I am off the throttle. There is no iol in the intake and none on the sparkplugs. I know its leaking out of the exhaust side of the turbo.
The v-band clamp for my down pipe won't seal up for some reason! this is especially annoying when the turbo is spitting out oil smoke. I think the clamp might be the reason why. Ill look into it when I have the time.
spin city
Old 12-20-2009, 05:56 PM   #20
drummersteve7
Boost Junkie Rehab!
nice man. glad to hear you got it up and goin.
get that smoke fixed, and show some ripper vids mang!
MadLab Racing
Southern Maryland
