Euro-r front and rear main seals
    I was wanting to out all new seals front and rear along with new timing belt water pump. How would be the best way to get the correct parts?
    You can go to the dealership and buy all the parts you need. All oem. Price varies depending on state as I found out through ppl I know that are in different states.
    Just tell them you want all the seals or ask for master seal kit and timing belt kit.
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
      Any seals should match a normal 97-01 Prelude VTEC.
      I wouldn't recommend the full kits on ebay, they are made of garbage rubber.
      If you don't want to spend dealership prices, I would recommend: https://www.rockauto.com
      or if you want OEM parts in particular, this would be the dealership to buy them from (cheapest): https://www.hondaautomotiveparts.com
        The problem I was having with dealer wanted a vin# said they couldn't look it up any other way. So I need to get 97-01 prelude parts.thanks y'all are awsome
          If you can find a source for part numbers specific to the Euro R, it would be best to cross-reference those numbers to those of the regular 97-01 H22A. Most parts should be interchangeable, if not identical, but some things may differ. Better to know ahead of time, rather than being caught off guard!
            My main concern are the crank seals if any one new if they would be the same?
              Good question because I read about the JDM oil pumps are different than the USD ones.
              Or do you mean like rear main seal?
              Keep Pushing..
                Your fine using USDM OEM seals. I have a F20B oil pump on my H22A1, just bought the standard seal for the H/F engines and it hasn't leaked in over a year of abuse.
                  Yeah rear main I ordered stuff for a 98 prelude. Clutch pressure plate release bearing was all identical to what came off. Decided not to mess with seals they don't look like they have been leaking I ordered them but going to wait till that is a must in case there are differences between the two.
                    If you have it apart I would go ahead and do it. Better than having it spring a leak later, also taking it aprt disturbs the seal and can cause a leak.
                    Under Construction​​​​​​​​
