Need help identifying part.
    What is this part called and it's purpose and can I remove it, or do I have to relocate it. It only attached to the harness, not the plenum, and the vacuum ports are open.
    Also what is the name and function of these. I think it might have something to do with either the ac system or ps, which I have neither. So can I unplug and remove this.
    Oh a little info on my cb. F20b/p28 tuned/p2u5 trans/ps,ac,egr,Iab delete/ h23 plenum, throttle body, internal dizzy, obd1 h22 injectors/stage 3 6puck clutch, and a bunch of other unimportant things.
    first one is injector resistor box, and you would have to relocate it, if you want to move it.
      Second pic is of fan relays. One for condenser, the other for radiator, IIRC.
      A&P-IA
        Ok thanks bro, I was wondering why my fan wasn't working, mybe the relays out. Ok I have another question, referring to the abs system. I have the unit in the trunk disconnected, because the motor is no good. I was wondering if I could unplug the entire system( basically everything colored orange) and leave all the mechanical parts intact. Will I encounter any problems with doing this
          what happend if u take the fan relays off?
            ur fans dont work
              Seriously? Uh, the fans would cease to operate...
              Edit.... Damn, Dani beat me to it!
                i took my off nd steel work
                  What about your A/C?
                    its gone..lol...i just have the left fan nd it works perfect without da relay
                      That's why, those relays are AC specific IIRC, and the AC fan is on the drivers side, and the cooling fan is on the passenger side.
                        Then I would guess that it wasn't the fan relay that you removed. With the fan relay removed, the fan would not work.
                        MR Thread
                        GhostAccord 2.4L Blog
                        by Chappy, on Flickr
                          OP, why do you feel the need to have a 6-puck clutch with a stock F20B?
                            ohh but yea thas y i took my off cuz i didnt c any differences
                              i 100% sure it was those 2 relays
