Old 01-29-2013, 10:26 AM   #1
Cb76Life
Cb76Life is cool... so far.
Motor revs up to 5000 rpm on cold start
So I recently replaced my transmission on a f22a1. Before i replaced the transmission everything in the car was working perfectly fine. After I put the transmission in it started to act up. When I start my car up it goes straight to 4,000 rpms and then back to normal idle then revs backs up to 4,000 rpms. I have checked the Tps on the car also the Map sensor anything that had to do with the airflow on the car. The computer also isn't throwing out any codes I have no clue what cause this.
Cb76Life is offline   Reply With Quote
Old 01-29-2013, 10:47 AM   #2
RyanD
RyanD seems to have made some friends! RyanD seems to have made some friends!
Send a message via Skype™ to RyanD
Your fitv is screwed. Replace it and bleed the coolant
"The Salty Old Bitch"
F22a4, Manual (Auto lasted to 368k)
My MRT http://www.cb7tuner.com/vbb/showthread.php?t=194341
RyanD is offline   Reply With Quote
Old 01-29-2013, 11:07 AM   #3
GeoffM
Administrator
GeoffM seems to have made some friends! GeoffM seems to have made some friends!
Try bleeding the coolant first. It does sound like the FITV, but you might not need to replace it.
It lets in air based off of the coolant temperature, and if you have no coolant it will malfunction.
Next, follow the guides on here for fixing your FITV.
You pretty much need to open the top of it (via phillips head screws) and turn the white
piece of plastic down all the way, then back it off 1/4 of a turn.
There's lots of other things it could be. There is an extensive DIY on here written by HondaFan. Look up that too.
MRT
Originally Posted by Tippey764 View Post
sneaky motherfucker
GeoffM is offline   Reply With Quote
Old 03-06-2013, 10:45 AM   #4
Cb76Life
Thanks guys I bleed the coolant and it now just revs up to 5k rpms and stays there I bought a new iacv and a fiacv hopefully it works
Old 03-06-2013, 11:25 AM   #5
GhostAccord
Revving up to 5k sounds like you should look for a vacuum leak.... May have forgotten a vacuum hose or maybe cracked one while doing the swap.
Aside from the TPS & MAP there is also the intake air control (IAC), Fast idle thermal (FIT) and Air boost (AB) valves that also have to do with air flow. Any one of these three could be leaking, out of adjustment or just not working.
MR Thread
GhostAccord 2.4L Blog
by Chappy, on Flickr
Old 03-06-2013, 11:34 AM   #6
Tippey764
Silver Member
I'm willing to bet you over tightened the kick down cable and its holding the throttle open slightly.
Tippey764 is offline   Reply With Quote
Old 03-06-2013, 12:22 PM   #7
erk
erk is cool... so far.
Do you have a vacuum gauge? Also try a little brake cleaner around the engine bay and listen for idle changes before you go spending money
erk is offline   Reply With Quote
Old 03-10-2013, 04:18 PM   #8
Cb76Life
Just changed the iacv and fiacv the motor wants to idle at normal rpms but still goes up to 3 rpm and back to idle speed and I don't here any vacuum leak
Old 03-14-2013, 06:19 PM   #9
91cbminn
91cbminn is cool... so far.
Did you try spraying anything to find a leak? Sometimes they are really faint and you cant hear them unless you use something like starting fluid to change the idle and find them.
91cbminn is offline   Reply With Quote
Old 03-18-2013, 03:29 PM   #10
AtLargeCB7
AtLargeCB7 is cool... so far.
same thing happen to my buddy when he was deleting his cruise control check the throttle cable honestly its prolly to tight
AtLargeCB7 is offline   Reply With Quote
erratic idle , rpm
