how much you get it for, I am thinking of buying one myself
new exhaust
Originally posted by highendurance92 View Postdamn not what i wanted at all
I recommend you buy an OBX oval style muffler or something and cut the can off and replace it with a nicer oval muffler. It'd sound a lot better, and probably be a little quieter.
does the honeycomb look like a filter cause if it does than it has that on the inside of said resonator or whatever it ends up being
Originally posted by 4thgentuner View Postthat a test pipe in place of a cat. converter...
look through it and there is no honeycomb center
bad for emmisions
As for emissions, he doesn't have to worry about that because we don't have it here in MI.
u bought the same systemm i got, i put a new header on when i got mine but yes it bolted up very well, u have to move the two hooks in the middle to get the rubber peices to line up. takes 5 mins to cut them off and reweld them. yes this is loud but from the outside of the car.dont get me wrong u can hear it inside the car but only on fast accerations. if u take it easy its not bad at all, but i like treating mine like my little race car\, so its pretty loud. take the silencer out i think it sounds better plus only takes 5 mins. to put back in if u sont like it. u STILL need your cat and make sure u tighten the bolts so it dosent leak. i did mine on a car lift so it was super easy. i love living on a army base!!
Originally posted by highendurance92 View Postim pumped cause i got a new exhaust for chritmas i dont have a header yet so im waiting to put it on till then but my question is if they dont bolt up how much can you bend the exhaust and are their different flex pipes so i can get them to work together
think about dc sport header an downpipe
