New Guy Just Bought 1993 Accord EX
Looks like a good place to start. Did you figure out why it was shutting off?
Member's Ride Thread
Originally posted by mercyboyI'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
Its crazy how big the gap is and I lifted the car and everything looks untouched on the suspension. No I haven't found out why it shuts off but I did find out that as long as I have more than half a tank of gas it wont shut off. It starts happening after it gets to half a tank of gas and the les it has the worse it gets.
Dam that body is minty.**Blk Housed Slut Crew Member #1**
fyi, your outer tail light gaskets are bad. That's why it looks moldy in there. Replace those and your lights won't fill with water everytime it rains.
Also the random shutting off could be either the ignition switch or the igniter unit inside the distributor. Does your tachometer jump right before it does it?
member's ride thread
91 Accord SE 176k
In response to your question, no the CRST truck is not mine but my neighbors. I also found out why the car shuts off at half tank. The fuel pump strainer was aftermarket and too short to catch the fuel off the return line. The return line is what keeps the strainer wet with gas when you brake. So $14 strainer and problem gone.
you have a good start with this, i always wondered how those sentra wheels would look on CB's.
Originally posted by Digitalpop View PostNo I haven't found out why it shuts off but I did find out that as long as I have more than half a tank of gas it wont shut off. It starts happening after it gets to half a tank of gas and the les it has the worse it gets.FRIENDS
DONT LET
FRIENDS
ROLL ON
ROTA'S
