So the problem everyone has popping the lbj out to remove the axle... I used a puller. But now I've got another problem.
I can't get the damn thing back in. Its a 97 Prelude. Same basic susp. setup as a cb7 though. I got the axle back through the rotor, put the spindle nut on and I can't move the bj in enough to get it in the lower control arm. I tried it with the bolt through the shock fork, and without it without any luck. Also I'm not havin much luck moving the rotor around to put it back in. I can move it, I just can't move it in enough to get in in the control arm
Probably doesn't mean anything but the reason the axle was out was to change the trans. Its an auto. Anyone got any ideas?
I'll take pics tomorrow to explain what I'm talking about.
