Please, if you need to replace your flywheel, and you aren't replacing it with a light-weight flywheel: DO NOT CHEAP OUT.
Flywheel in question was bought from EBAY, advertised as Dorman/ATP brand.
I made that mistake, and it turns out the flywheel is HORRIBLY out of balance. I get a nasty vibration around 1200 rpm that I didn't have before, it literally shakes the entire car violently. Not only that, but the pilot bushing (transmission input shafts fits into the bushing; it is in the flywheel) is already making squealing noises due to the imbalance (uneven wear).
Please! Don't cheap out! I found out you can order an OEM flywheel for only $40 more than this cheapo flywheel, and that's what I'm doing now.
Avoid my mistake, and you won't be pulling your transmission again, like I get to.
