f20a or...f20a?
    f20a or...f20a?
    i've been searching but havent found what i'm looking for..the re are 3 f20a motors the sohc non vtech,the sohc vtech and the dohc vtech...one of them is supose to be a direct swap into our cars and mount to the f22a tranny perfectly but which one is it?..my motor probably doesnt have much life left in it and i don't want to get rid of my cb7 just because the motors gone.
    92 Accord EX - SOLD
    PSN: REDxMAN-_-
    MR===>http://www.cb7tuner.com/vbb/showthread.php?t=146478
    i never seen a f20a sohc vtec.
    i seen f20a sohc, f20a si, and the only sohc 2.0 vtec motor i know of is the f20b , its jdm i believe.
    if i can do it again, ill go dohc!
    dohc in general is a upgrade to a cb. everything is smoother imo
    edit
    you spelled vtec wrong-200+ posts
      *Ehem* I feel I should chime in here.
      F20A DOHC is the best.
      F20A SOHC is weeeeaaak. (Sorry F20ACB7 )
      F20A VTEC = Never existed.
      P.S. Check the MRT
      R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
        i said if i can do it again ill go dohc so im not offened lol.
        but my 2.0 wasnt a weak motor, in hp it wasnt the greatest but the motor itself was strong.
          Lol, I was talking power. I'm willing to bet that it's a nice reliable motor though.
          BTW, what ECU are you using?
            P.S. Check the MRT
            I think there is a f20 dohc vtec..a or b not sure
              http://www.tigerjapanese.com/index.p...mart&Itemid=26
                p12, the sohc 2.0 is based of a f22a4. no secondaries etc..
                fyi to the op, all jdm f22a were a6 related, secondaries and all..
                  is the f20a sohc rated for 150hp?
                  92 Accord EX - SOLD
                  PSN: REDxMAN-_-
                    F20a DOHC is 150PS
                    F20a SOHC is somewhere around 130PS+
                    F20B SOHC non-VTEC is 130++
                    F20B SOHC VTEC is 150PS
                    F20B DOHC VTEC is either 180PS or 200PS
                    Click sig to view MR thread
                    Links to other rides:
                    Honda Accord Euro-R
                    Honda Odyssey Absolute
                    Honda City I-DSi
                    Honda Stream
                      Originally posted by blizzard335 View Post
                      F20a DOHC is 150PS
                      Doesn't all the f20a heads bolt directly up to the f22 blocks?
                        sohc
                        F20A
                        This engine series was used in the Honda Accords and Prelude`s in Japan and Europe. The DOHC F20A was also derived from this engine (see below).
                        Specifications
                        Bore × Stroke: 85.0 × 88.0 mm
                        Displacement: 1997 cc
                        Compression ratio : 9.5:1
                        Valve Configuration: SOHC, 16 valves
                        Max output : F20A2 110 Ps @ 6000 rpm (PGM-carb)
                        Max output : F20A4 133 Ps @ 5400 rpm (PGM-Fi)
                        Max output : F20A5 150 Ps @ 5400 rpm (PGM-Fi)
                        Max output : F20A7 135 Ps @ 5600 rpm (PGM-Fi)
                        Max output : F20A8 145 Ps @ 5900 rpm (PGM-Fi)
                        Max torque : F20A2 16.1 kg m @ 3800 rpm (PGM-carb)
                        Max torque : F20A4 18.5 kg m @ 4300 rpm (PGM-Fi)
                        Max torque : F20A7 19.3 kg m @ 4400 rpm (PGM-Fi)
                        Max torque : F20A8 138ft/lb @ 4400 rpm (PGM-Fi)
                        Fuel consumption F20A8 Urban - 25 mpg Highway - 34 mpg
                        Fuel consumption (Japan Combined Cycle) : 9.6 km/l (PGM-Fi), 9.8 km/l (PGM-carb)
                        dohc
                        F20A
                        This engine was used in the 1990–1993 CB3 and CB4 Honda Accord 2.0Si and Si-T in Japan.
                        Specifications
                        Valve Configuration: DOHC, 16 valves
                        Compression ratio: 9.5:1
                        Max power: 150 hp (112 kW) @ 6100 rpm
                        Max torque: 137 ft·lbf (186 Nm) @ 5000 rpm
                        UKDM 93 CB3 Page (1) H22A U2Q7 LSD
                        UKDM 91 4ws Page (3) OEM Minter
                        NOW H22A U2Q7 SWAPPED
                          i dont think its directly for the f20b's sohc or dohc
                          but for the f20a's it is.
                          i can be wrong on the f20b info
                            both the sohc and the dohc f20a heads will bolt up using the f22ax headgasket. the f20a dohc head is the same head found on the jdm f22b dohc. both heads are stamped "pt2" i believe.
                            Originally posted by d112crzy
                            So you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
                              so the sohc f20a will bolt in place of my f22a1 with the same motor mounts and f22a1 tranny?
                              92 Accord EX - SOLD
                              PSN: REDxMAN-_-
