the rear passenger side window, won't go all the way up...it rolls down perfectly and when i go to roll it back up, it leaves about an 1.5 inch gap. it won't close all the way. i've taken the door panel off, to see if it was getting stopped by something, but there is nothing that is stopping it...does anybody know how i can fix this?
Rear passenger side window...
ya
i had the same problem it was my motore u can go to a junk yard and get a use 1 with the rail for cheap cause the motore is 85 and the rail u can only get from honda so maybe 150 or less but 75 at a junkyard is better and i loved it my window wasnt working gave me time to do tint on them with all the glass work but just say if u dont have tints good time to do it ur self save more i did
4 door ex-l
u could also remove the glass from the track and re-align it. i plan on doing that for my car, but i havnt had the time. i'll try to do a DIY on it when i do... it shows how to do it in the a guide i downloaded.. i'll screen shot that too when i get home.la passion de la moto <3
the spoiled girlfriend wants rims!
With that piece broken, it won't go all the way up. It's not the motor, it's the regulator.
The motors and regulators come separately from the Honda dealer, making it a hassle to assemble them. The aftermarket ones aren't nearly as good (I have 2 aftermarket ones, both are very slow). However, they're much easier to work with... just slap em in.
As for "removing the whole system"... the motor is attached to the regulator, with a loaded spring... which is why it's tough to assemble and disassemble the thing. I prefer to buy them assembled, even if it means getting crappy aftermarket stuff. The motor and regulator ARE the "whole system".
When you remove the regulator, be sure to secure or remove the glass.
If you remove the glass, don't clean the "dirt" on the sides... that's for lubrication, and your window will give you trouble if you clean it off. Not that I know from personal experience or anything...
