OEM fog light install question
    I bought some oem fogs from a fellow cb with the oem switch. However there is no wiring harness can someone point me to the proper wiring harness I can get to wire all this up? I would prefer the oem from sonshonda but I don't know the part number. But if that's not possible what's a good universal one? I got a 90 sedan hope you guys can help me out.
    Wiring harnesses for these are getting rare and you cannot buy them from a store anymore. I'd check the FB group or the buy/sell here when you can.
      I have a complete 90-91 fog harness I don't plan on using. Pm me.
        use an aftermarket harness and add oem switch to it. cheaper alternative and u can use it separate of headlights. WINNING
          Shoot me a link to where this harness is so I know which one to get please
            i also need a fog light harness. I think I'm going to order this one. http://www.ebay.com/itm/Brand-New-Un...9VOeLp&vxp=mtr
              Yes, this is the route you should go. If you want to hook up the stock switch, you can use this pinout, and tap into the White wire on that harness for Pin E:
