Old 10-27-2015, 02:00 PM   #1
JFISHTHECREATOR
JFISHTHECREATOR is cool... so far.
Send a message via Skype™ to JFISHTHECREATOR
Brake issues : no pedal
As the title says, I'm having an issue with my brakes .... on my 1992 EX wagon, I have not started a MRT for this one yet.
Anyways, I got it and the brakes were shot, pedal to the floor , then it would grab. So i bought new pads for the front and back.
The back calipers would not compress with a c-clamp , some said that you thread them in with a large flat head screw driver(I didn't try this yet)? I put the new pads on and they didnt fit due to the caliper being out , so the old ones are back there still.
So I pressed the caliper pistons in the front back in , and installed the pads. I pressed the brake pedal about 20 times, without any pressure. So I tried bleeding the lines. And of course , the back right released some fluid , but would not pump any more out.
So , I went to the front right, and i bled the crap out of that line and the front driver line. Since the front lines are connected to the back , I figured they would be bled. Nope , no pressure still.
I ended up using a full bottle of fluid bleeding with no luck. So I went and bought a NEW , not re-manned master cylinder (1" bore). I bench bled it and put it on. Again , used a full bottle of fluid, with no luck . I even gravity bled all four wheels.
A friend suggested bleeding the ABS , So i did , I used 2 full bottles. There is no air in it either. Still no pressure. (pedal to the floor , and brakes don't grab)
I am lost as to what would be the issue
JFISHTHECREATOR is offline   Reply With Quote
Old 10-27-2015, 02:08 PM   #2
Kev1990
Kev1990 is cool... so far.
Well lets start off simple since I saw nothing about you bench bleeding the mc you could try that. I'm not to familiar with the ABS systems on cb7's ill try to help a little more after work.
Kev1990 is offline   Reply With Quote
Old 10-27-2015, 02:17 PM   #3
sonikaccord
The ABS and normal braking system are normally isolated. My ABS modulator is completely empty, with no change or noticeable change in performance, however, my ABS system is disabled.
Yes, you do screw the rear calipers in to compress the piston.
Is your bleeding order correct? Do you see any leaking? Keep trying!
Edit: also, can you explain your bleeding process to help us visualize what you are doing?
YouTube Clicky!!
Old 10-27-2015, 02:17 PM   #4
DCB7
DCB7 is cool... so far.
This is the tool for compressing the rear caliper. I borrowed this from autozone. It can be threaded down with a huge flathead screwdriver.
As far as pressure, maybe a leak in a brake line (that's a lot of fluid)
DCB7 is offline   Reply With Quote
Old 10-27-2015, 06:05 PM   #5
F22Chris
Check the vacuum line/check valve for brake fluid too.
Bleed farthest from the master to the closest if you haven't already. Can you build up pressure at the pedal with the car off? Are the brakes hard all the time?
Old 10-27-2015, 06:21 PM   #6
JFISHTHECREATOR
I did bench bleed the MC
Old 10-27-2015, 06:23 PM   #7
JFISHTHECREATOR
There are no leaks, I even marked the master cylinder and let it sit for a week , and level did not move.
right rear , left rear , right front , left front.
Old 10-27-2015, 06:24 PM   #8
JFISHTHECREATOR
I did not see any leaks , and the level in the reservoir did not drop. Thanks for the info on the calipers
Old 10-27-2015, 06:26 PM   #9
JFISHTHECREATOR
There wasn't any in the check valve. I bled correctly(the way you suggested).
And there is no pressure what so ever. And no , there is literally no pressure , pedal goes to the floor, vacuum booster would be culprit if it was hard.
Old 10-27-2015, 06:27 PM   #10
JFISHTHECREATOR
video
https://www.youtube.com/watch?v=yjhgBE7SFwE
This is a video explaining the situation
Old 10-27-2015, 09:38 PM   #11
F22Chris
Get a small flathead and carefully pry up on the caliper piston boots. Does fluid come out?
Edit: watched video. Check for vacuum leaks from the booster, man. You should be able to build up pressure with the car off.
Old 11-06-2015, 04:48 PM   #12
JFISHTHECREATOR
I turned the rear calipers in , put pads on , bled correctly once again , and still no pressure.... what are you referring to as a vacuum leak? i haven't found any..
Old 11-08-2015, 01:10 PM   #13
JFISHTHECREATOR
smoke test?
Old 11-08-2015, 03:24 PM   #14
JFISHTHECREATOR
i put the wheels back on , air cleaner on , all vacuum hoses on , battery in.
started, no pedal. e-brake, no pedal. rev, no pedal.
but i dared anyways. e-brake on, pressed foot until brake was on the floor , threw it in reverse. didn't move.
released e-brake, still didnt move. let off brake, started rolling slow, so i hit the brake again , and still no pressure.
builds no pressure while off.
took it down my street , pedal has no pressure , and it BARELY grabs. by barely , I mean at 10 mph , it took 40 feet with it floored to stop. On the way back up the street i took it up to about 25 mph then floored it , still no pressure and it grabbed the right front hard, hard enough to lock only that wheel up for about 5 feet.
I'm assuming that only the right front wheel is getting any pressure.
all wheels have been bled , new MC.
Old 11-08-2015, 05:22 PM   #15
djcaz_aom
djcaz_aom seems to have made some friends! djcaz_aom seems to have made some friends!
Sounds like you have a leak on the secondary system, which is Front left, Rear right. Check the modulator.
Also, you're bleeding the brakes in the wrong order. You should be bleeding them in circuits.
RL, FR; RR, FL.
So many people do it incorrectly.
Next, test the check valve.
Disconnect the vacuum line at the booster and start the car. It should idle correctly. If not, replace the check valve.
I am almost positive you have a leak somewhere.
Good luck with this.
djcaz_aom is offline   Reply With Quote
Old 11-10-2015, 09:55 PM   #16
JFISHTHECREATOR
If i remove the vacuum line at the booster, it has the hunting idle (1500-2100 rpm fluctuation).
As for the abs system, there are no codes what so ever, I have bled the entire system , it worked properly when I bled it.
With the vacuum line at the booster removed, there is a harder pedal, almost what a normal one would feel like.
And now , with the vacuum line at the booster connected , if I rev the car or am on the gas and then hit the brakes directly after , it has a normal pedal feel , but not normal stopping power.
should I go get a few check valves from the junk yard? maybe a booster too?
As for the bleeding being incorrect , I didn't use any sort of self bleeding tool , or pump the brakes. I just let them gravity bled. I did : (driver rear, passenger front, passenger rear, driver front) .
I did the furthest from MC to closest thing , until I found a post from someone else on here stating to do (driver rear, passenger front, passenger rear, driver front). At that point I did it that way.
Old 11-12-2015, 02:08 PM   #17
JFISHTHECREATOR
nobody has an idea as to what is happening?
Old 11-12-2015, 02:19 PM   #18
sonikaccord
I would definitely try another check valve, and get a friend to pump the brakes for you.
YouTube Clicky!!
Old 11-22-2015, 11:11 AM   #19
JFISHTHECREATOR
I did not remember to grab a check valve while at the junkyard. I had someone help me bleed the whole system , and lube slide pins... still no luck. I will try the check valve from my sedan , and see what happens. If that don't help, I will attempt to adjust the push rod down at the brake pedal.
Old 11-24-2015, 06:16 PM   #20
F22Chris
Did you fix this damn thing yet?
