Another Newb Question: Speedo
    Back again with another question.
    Sometimes the speedometer moves, most of the time it stays at zero. LKQ is having a 40% off sale so I was going to make a run up today. What should i look for? I heard on another thread that it was something inside the tranny?
    Any help would be appreciated! Thanks
    It could be your VSS. Vehicle speed sensor which is located on the tranny near the rear mount. It has one plug on it and 2 power steering lines going to it. If you good 93 accord vss sensor I’m sure it will come up with a pictures. You should only need the top portion which is held on but 2-3 10mm bolts.
    ~Nick~
