ok so my d4 light is still on i got my tcu repaird still no good solinoids work and if i pull the back up mem fuse the car starts in park with out the d4 light on then it will shift normally untill i shut the car off and if i dont reset it agen the d4 light is on on startup in park aswell as the park light and only 2 & 3 work on the shifter when driving and you must shift it manually from 2 - 3 becuas in d4 it feels like its in third gear also i replaced the main relay thinking it might have been tht ohh and the shift switch aswell solinoids do work and when car is shifting after reset in d4 1-4 shifts great so something is building up errors and excuse my language fuking me on start up on anothr note if i reset the car and put the backup mem fuse in the d4 light will go on
im going to try jumping the wires from the tcu to the solinoids directly to bypass all those shotty old connectors hopefully ill see some light at the end of this long ass money pit
