I used to have an old thread about the conversion and have done lots of research since then. I am looking into doing the Acura CL 2.3L Hub replacement to have floating rotors instead of the captive ones. I have a Nissin 25T Bracket and caliper set I got from I believe a 97 Acura CL 2.3L. From looking on rockauto, carparts and other sites I can only find 23mm in floating with 4 lug but can find it as 25mm captive, which is what im trying to get away from but they both list they use T25 on rockauto??. Did I mess up by getting a 25T bracket/caliper and need to get only the 23T bracket and if so will it bolt onto right onto the caliper?
ROH Conversion, will 23T bracket bolt onto 25T Caliper
