93 UK Coupe questions
    Hey guys!
    Wandering if people have done the roh with Acura rl calipers with abs
    As I had the intention that BB4 front hubs and arms would bolt up but they did but no ABS support and I'm not looking to delete it as I want the car to remain factory but oem upgrades
    Also if anyone is selling a front ARB/ sway bar as mines bent from an accident 😩
    Also if there are any other companies which sell a ARB/sway bar for the rear ?
    Also looking at Yellow Speed Coilovers as they can be found easily with warranty in the UK
    As I've developed a front right side knock in my strut tower I'm sure !
    Helpful info would be great thanks!
    And yes I know there's roh posts but those parts I can't find in the UK or EU market at all and sucks for us in the UK for those parts!
    2000 accord v6 spindles will bolt on and allow to you to retain the abs sensors. they are also roh.
    COUPE K24
      I just finished my RL caliper setup this weekend on a 92 EX coupe which of course has abs.
      Go 5 lug using 2000-01 Accord V6 spindles and hub. DO NOT get 99 Accord V6 spindles OR 4cy Accord spindles. You need the Fat Four RL caliper bracket kit. The RL calipers off of an 05-12 I think Acura RL. A pair of 350z w/Brembo pkg front rotors. I would definitely get a braided brake line kit for all four corners. I literally bought a $20 braided line kit for the 98-02 Accords which comes with enough for all four corners but you’ll only use two for the front. The other two will not work for the CB chassis rear lines. One thing you need to keep is your banjo bolts from your stock CB calipers. The later Accord ones are a couple threads too long. That should cover the front.
      The rear is 97-01 Prelude hubs with integra type-R or 00-01 Accord V6 rear rotors. I use the type-R. Get two new 97-01 Prelude rear hub nuts also. You’ll have to space the rear abs sensor down to clear the Prelude hub exciters that the abs sensor reads. It’s two longer bolts per side and three washers on each bolt to space it right. I got that stuff at Autozone. The rear braided lines I have are from a Goodrich 90-97 Accord braided line kit. You won’t use the Goodrich front lines. They’re too long for the new front spindles.
      After that you gotta find wheels that work. Acura TL 17x8 +45 types are commonly used.
      Nicely painted RL calipers are the eye candy for sure.
      ~Mark~
        will have a look for these on ebay or around forums in the UK
        Thanks for the info much appreciated! but one bummer thing im going to say is that i want to keep the car 4LUG as im running my wheels ive wanted for ages which are work VS-XX's 17x7 and 17x8's at et 32
        so 4lug is what i need not 5 lug so could i then use preludeBB4 hubs pressed into the V6 Leg etc and the rear brakes arent something im going to change as ive recently purchased all new rear calipers
        https://www.ebay.co.uk/itm/98-99-00-...IAAOSw53hbpXXD
        Have Found these but not sure if theyre the ones you guys are on about and for the year of vehicle i know somone whos breaking this shape accord... but not sure if those legs/knuckle will work
        https://www.ebay.co.uk/itm/HONDA-ACC...EAAOSwEK9UDNFx
