At idle the tach reads just at 1000. To me it seems to idle at 700 or so, right where it should be. Does it sound legit that the tach might be off or is it the consensus that I'm getting old and my hearing isn't what it used to be.
Rpm's not accurate?
I've had a couple that idled high that don't really sound that high. Is this when all accessories, AC, lights, etc. are off? High idle is usually a vacuum leak somewhere.
What happens if you disconnect the IAC? What troubleshooting, if any, have you done?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
