Thread Tools Rating: Thread Rating: 6 votes, 4.00 average. Display Modes
Old 02-26-2017, 08:00 PM   #261
SilkyCB
CB7tuner Member
SilkyCB is cool... so far.
Excited to see this start coming together
SilkyCB is offline   Reply With Quote
Old 02-26-2017, 10:56 PM   #262
oneoffaccord
Accord of the Month: November 2006
oneoffaccord seems to have made some friends! oneoffaccord seems to have made some friends!
Send a message via AIM to oneoffaccord
Quote:
thanks man I'm highly excited aswell
oneoffaccord is offline   Reply With Quote
Old 02-26-2017, 11:14 PM   #263
coltonfrostcb7
CB7tuner Member
coltonfrostcb7 is cool... so far.
man i wanted to do this to my car but i dont have the room to take it that far down
coltonfrostcb7 is offline   Reply With Quote
Old 02-27-2017, 05:14 AM   #264
oneoffaccord
Quote:
what do you wanna do to it?
Old 03-13-2017, 12:08 AM   #265
oneoffaccord
Here's a lil update, I had these strobe lights for years. Legit for years, the box was dusty as hell. I will be installing these in the bumper lights. Also do a separate harness for the speedometer, knock sensor, vtec solenoid and pressure switch.
Old 03-16-2017, 07:04 PM   #266
Rilas
Gold Member
What master cylinder is that, the S2K?
__________________
Old 03-17-2017, 05:57 AM   #267
oneoffaccord
Quote:
Brake master cylinder?
Old 03-17-2017, 07:24 AM   #268
Rilas
Gold Member
Sorry the clutch. I know the brake is the RSX.
__________________
Old 03-17-2017, 08:25 PM   #269
oneoffaccord
clutch is S2000
Old 05-28-2017, 11:39 PM   #270
oneoffaccord
Going to have some updates tomorrow, gotta upload a bunch of photos.
Old 05-29-2017, 09:11 AM   #271
oneoffaccord
S2k clutch master and clutch line installed.
Brand Honda bolts.
Old 05-29-2017, 09:15 AM   #272
oneoffaccord
RSX booster and master installed, Mocked up the Wilwood prop valve
Made a mounting plate for the prop valve out of carbon fiber
ready to be mounted to the car
Old 05-29-2017, 09:23 AM   #273
oneoffaccord
Started to run the brake lines from the master to the prop valve. Its fitted with banjo and AN fittings. I still have to undercoat both wheel wells and part of the exhaust tunnel.
Mocked up the fuel lines brake line. Ran the rear brake line with the fuel for now. Will finish that up tomorrow.
Since I had both front Goodridge braided brake lines from my last build I decided to run AN fittings to the brake hoses.
Old 06-16-2017, 08:23 AM   #274
sepulveda87
CB7tuner Member
sepulveda87 is cool... so far.
does the s2k cmc make a difference in performance? Same as well for the bmc from the rsx?
sepulveda87 is offline   Reply With Quote
Old 06-16-2017, 06:41 PM   #275
oneoffaccord
Quote:
i ran both in my last CB, and it doesn't. I just looks cleaner
Old 06-28-2017, 02:04 PM   #276
apalileo
CB7tuner Member
apalileo is cool... so far.
I like the combo of OEM master cylinder with the adjustable proportioning valve, especially having front and rear outputs rather than splitting a single from the master cylinder. Everything looks real clean.
__________________
1993 Accord DX | Rosewood Brown Metallic
www.anthonypalileo.com
www.anthonypalileo.com/watches (secret link)
apalileo is offline   Reply With Quote
Old 06-30-2017, 11:42 PM   #277
oneoffaccord
Quote:
thanks man, went for a clean functional look this go around
Old 11-06-2017, 05:52 AM   #278
oneoffaccord
hey peeps. a little update. still working on the accord. its coming along great. I'm going to have to update my photobucket to upload photos.
Old 11-21-2017, 11:37 PM   #279
wtfisafleek
CB7tuner Member
Don't even bother paying man, use another service that's free. Imgur works great for me.
Old 12-07-2017, 12:32 AM   #280
oneoffaccord
Quote:
thanks ill look into that
