F22A1 Firing on 2 Cylinders
    Good Evening,
    I wasn't sure where to post this topic, if it's not in the correct spot just delete this post. I have a F22A1 in a 97 Honda Odyssey. It's almost like looking at a CB7 under the hood. I am running a OBD1 PT6 ECU and I'm having trouble with either the injectors or distributor. I'll try to be brief and let you know what the problem is, and I'll list everything that has been modified.
    Problem: Looking at the F, the left 2 cylinders 1 & 2 fire, 3 and 4 don't fire. If I unplug cylinder 1, cylinder 3 and 4 start to fire (2 not affected). If I plug back in cylinder 1, 3 and 4 stop firing (2 not affected). If I unplug 2, only cylinder 1 is firing only. It's either cylinder 1 spark or fuel injector/wiring.
    I have 180 compression on all 4 cylinders. I rebuilt the motor with stock internals. I've tried timing, (distributor and cam) I've tried rewiring my harness, and checking grounds. I just can't figure this weird problem out. I have no codes on the ECU (tried 3 different ecus), I have went through and fixed every code I had.
    Modified Parts:
    F22a6 Cam
    F22a6 intake
    H22a4 Plenum
    H22a4 Fuel Rail
    F22a injectors
    F22a Fuel Pressure Regulator
    Milled Head (not sure how much)
    Custom wire harness (self built)
    Deleted ABS (not sure if matters)
    Deleted SRS (not sure if matters)
    If you would like to see video, I can record and post a video of this problem if that helps with diagnosing.
    For Sale Thread CLICK HERE!
    1991 CB9 EX Wagon
    1990 CB7 EX Sedan
    1997 RA1 LX Wagon
    CB7Tuner Discord CLICK ME! -- http://www.cb7tuner.com/vbb/showthre...02#post3285402
    Sounds like an ignition problem. What distributor are you using? Did you make custom spark plug wires? I wonder if you wiggling the wires back and forth when you take them in and out is shorting them out. Just to be clear, I think when looking at the motor from the front of the vehicle the cylinders are, from L to R: 4 - 3 - 2 - 1.
    Does the inside of the distributor cap look ok? Shouldn't be cracked or burned up looking inside.
    If that doesn't shed any light on it, you might drop in to ericthecarguy.com and ask over there (no connection to him, I just appreciate his vids and have studied them). He's made some really good videos on old Honda ignitions and seems to know them really well.
      New NGK plugs and wires, it's a 90/91 accord distrubor (coil inside). I've tried different plugs, different distributors, different injectors. Even tried wiring up different wires for the dizzy and injectors and bypassed the harness.
      1991 CB9 EX Wagon
      1990 CB7 EX Sedan
      1997 RA1 LX Wagon
        The rotor in the distributor should only fit one way if I'm not mistaken, so that can't be it... with you swapping all those parts maybe that rules them out.
        Has this motor ever ran correctly with the harness you made?
          Nop, it ran back in the day when it was in my previous CB that ended up getting totaled. Different harness of corse. I've been doing some reading, I'm thinking it's a ground issue. I'm going to keep poking around with the grounds.
          1991 CB9 EX Wagon
          1990 CB7 EX Sedan
          1997 RA1 LX Wagon
            I know when I didn't have my thermostat ground connected properly, my car wouldn't start at all! Freaked me out, the car cranked, but there was no fuel or spark.
            I'm faster then a prius
              Well I found out it's not a ground issue, I think it's interference with the signal wire on the distributor.
              1991 CB9 EX Wagon
              1990 CB7 EX Sedan
              1997 RA1 LX Wagon
                Glad you're figuring it out, let me know if you need an extra hand.
                  Good Evening,
                  Firing order is 1-3-4-2 for Honda's. In your case cylinders 3 and 4 are causing some issues.
                  Your custom harness... are the CYP/TDC/CKP wires shielded properly? Are the polarities right? Are they twisted pairs? Do you have a noid light to check your injector firing order?
                  YouTube Clicky!!
                    After my custom wire harness, I couldn't get the motor firing right. I put a OEM OBD1 Odyssey harness in the car, didn't make a difference on firing. Before I start tearing this motor down to pieces to figure out what it could be I had a question about the cam. Currently in the motor is a F22B6 cam in a F22A head. I was told the A6 and B6 cam is the same pretty much, if that's true great. The old F22B6 motor was overheated bad... I used the F22B6 from the warped head in the F22A head. Can a cam get damaged from a warped head to make a noticeable difference in firing or can the cam warp as well? I'm about to take a F22A6 cam and stick that sucker inside and see if it makes a difference.
                    1991 CB9 EX Wagon
                    1990 CB7 EX Sedan
                    1997 RA1 LX Wagon
                      If I am not mistaken I do t think you can use the pt6 ecu. If you do I think you still have to swap a couple pins around on the body to get it to run. You should try a stock 97oddy ecu for the 4 cylinder. It should run fine. Also everything should be used from the f22b motor. Dizzy,injectors, injector resistor( if it uses one) even stock oddy engine harness. The ecu may run the motor a tad bit weird but still on all 4 cylinders.
                      my new turbo build
                        Results:
                        Not sure if the head gasket caused this or what, any ideas?
                        1991 CB9 EX Wagon
                        1990 CB7 EX Sedan
                        1997 RA1 LX Wagon
                          I had the block and the head decked/milled, do you think firing on 2 cylinders is because of the timing being way off? The 2 clean cylinders are the ones not firing. I have an adjustable cam gear so I can adjust the timing, but I don't know how much the timing would be off if that's the case.
                          1991 CB9 EX Wagon
                          1990 CB7 EX Sedan
                          1997 RA1 LX Wagon
                            Your initial description says 3 and 4 fire is you disconnect #1- this would seem to be a wiring issue, not cam timing or head gasket related.
                              Is it possible to have a bad fuel pump but have steady pressure? I checked the fuel pressure and it was 35 PSI and would raise under acceleration. I dropped another motor in to see if the motor I built was the problem. Problem still persists.
                              1991 CB9 EX Wagon
                              1990 CB7 EX Sedan
                              1997 RA1 LX Wagon
