i am back
    i am back
    my last login was
    You last visited: 01-14-2014 at 03:15 PM
    but i finally got another accord
    this time coupe 2dr 5spd
    picked it up for 250$ was said to have bad compression and burnt oil ring in 4th cyl
    well 1 day after owning it's head is now in my basement 1 chipped valve completely done exhaust valve.. saved from the wreckers become a washing machine tin can
    but block looks cyl are like new great for 300km it looks perfect pistons look new still abit of carbon here and there but mostly great
    now to the parts store to get a valve tommorow
    do the f22 f23 h22 h23 all share the same size exhaust valves
    can get a deal on used valve but would like to know if they fit
    well it looks like f22 and f23 share same valve sizes. from my research it seems the v6 is the same as well and when i called honda dealer locally it was 14$ cnd
    he did not ask me if it was a 4cyl or v6 only manual or auto ???? (does that make sense no) so that kinda confirms what i was thinking that there the same
    1+ to honda dealer that had parts cheaper than my local napa auto parts 45$ for 2 min order is 2. and oem honda at that still amazed at how perfect everything is at 320 000km, looks like the valve seals on cyl 1 # just sarted leaking so gonna change them but this is a if its not broke dont fix type budget
    so i will be re use the head gasket that came off looking great like it just came out of a new package lol not broke (will be doing a first try with the aerosal type copper gasket from napa ) so will let you all know how that goes
    when i got it there was no headgasket leak in it coolant or oil detected, if it doesnt work then i will get a new headgasket but budget right now is none
    waiting for EI benifits to come in been off work for 2 months rrr truck broke down 2003 6.0l diesel crewcab 4 door f250 3/4 ton. and cost to fix it is unkown but 1 sensor for that Ford M**F* is 240$ and that didnt fix it so when this honda accord came along going to scrap yard well it seemed that it would be cheaper to get this honda fixed for now
    well waiting for dealer to call to pickup the valve
      Use a new head gasket.
        i will i plan on take the head back off in a month or 2 when i have cash flow and replace the other 7 exhaust valves atleast but for now i have some permatex aerosol copper headgasket spray and this is what the stuff is for so i plan on reuse the gasket and retorqu it to same specs with the copper spary in there it should be good to go will let everyone know tommorow morning gonna pull a not going to bed tell the head is back on and it starts tonight
        the knock sensor on the back of the block was completely rusted away from the bolt part and hanging in the air wonder if that had to do with it breaking the one valve ??
