So I'm usually pretty good at diagnosing this car. But now, I am officially stuck.
It failed smog early last month and I had replaced the o2 sensor. It passed well and they fixed my timing a little.. let's just say I might've not stuffed my wiring well and the o2 sensor connector ripped apart lol.
So I drove it around a few days just loose wires and connections because I was busy with school. Going to work one day, I turned in the parking lot and the car just cut off! I rolled into a parking space and couldn't get it to start! I know it would start even without an o2 sensor plugged in.
Anyways, the Engine light was on (Code 1) and several TCM codes which were codes (1,2,3,7,8,14). That is wayyy too many codes out of nowhere. Shift solenoids were replaced last year, besides there can't be a way that both dies at once. Also replaced the TCM with another same numbered one from junk. Still 's' light, and infinite crank no start.
Haven't replaced ECU but I'm not getting any more engine codes since fixing the o2 sensor wiring and replugging it in correctly.
Already tried resetting the battery and ECU. Anytime I plug it in and turn the car 'ON', the 's' light automatically pops up. Already tried new main relay and tried resoldering my old one. But I did not reset the ECU or battery when I tried it with a brand new one.
Whole distributor including igniter was replaced a few months ago and the parts were relatively new.
Please let me know guys, I really need this pos
