The indicator (to let me know the brake light is out) on the gauge cluster is not illuminated. Could that still be the brake light switch causing her to not have brake lights?
Brake lights all dont work
The power and ground wires are in the harness which lead to the connector at the tail light. Use a volt meter to determine you have power to the power wire (see your manual) and use a proper ground, do you get 12V ? (make sure the brake is on). If not, work your way back to the switch, then to the fuse box...
Sorry for the lack of part name but, I remember when I installed my red/clears there was a little brown switch inside the brake lamp itself which was dead. I think it's called the brake light relay? I cannot remember the name but it is a brown relay type box.
Anybody know the part name/#? I have the honda oem bag sitting on my desk at home but I am at work right now.Keep Pushing..
https://www.hondaautomotiveparts.com...2)&vinsrch=yes
37540-SM4-A01 025 001 SENSOR, STOP LAMP FAILURE 38.00 26.60
37540-SM4-003 026 001 SENSOR, STOP LAMP FAILURE 38.00 26.60
One is left & one is for the right side. (Lol I forget which is which.) I called Honda last time before I ordered mine.Keep Pushing..
Today we tested the Brake Light Switch, and replaced it with the one from my sedan.
Only getting .15-.25Volts to the tail lights Just before the harness. Near tail light
Battery and Fuse 12.Volts
Running lights have 11.35Volts Just before harness. Near tail light
Grounds are good. because they worked for the running light tests just fine. same ground.
What could cause this?
I would rewire the whole rear end using the power source from my 3rd brake light, if it was getting 12v. But I found that I wasn't getting 12v using a multi- meter.
It's losing power somewhere from the Brake Light Switch> to my tail-lights. I believe.
Really Don't want to have to take it to a shop.
Why is it losing power?? I'm just trying to understand why the brake lights don't work so I can get my GF's car back on the road saftly.
Have you replaced anything before you swapped out the tail lights? Did you kink any wire when doing the install? That amount of voltage tells me it's encountering some kind of resistance whether there is a small cut in the wire and it's grounding itself out or there is a lot of corrosion somewhere.~Nick~
Originally posted by Raf99 View PostUg, did you look at the brake switch? ie - take it out...?
Running lights work
Blinkers work
reverse lights work
no Brake Lamp failure light on dash..
Originally posted by alex_eats_rice View PostJust gonna take it to a shop. I'll let you guys know what it was if they can find it
Today we put the car into Alaska Import Service & Repair, to get the no brake lights problem fixed.
The main wiring Harness in the rear between the back seat & Trunk, and the tail lights somehow came apart.
$170 later, my GF has functioning Brake lights.
We think when taking the housing out (to put Red/Clears), I may have unknowingly pulled the harness connection apart ever so slightly.
Just went for a drive, stopped to check tail lights, and they didn't light up!!
Checked the Main Harness behind the back seat where the mechanic showed me was un plugged, The harness is Zip Tied together so it wont come loose, but yet it didn't light up..
we pushed the harness in hard and the Brake Lights work again. Going to have to find a way to secure it even tighter.
Sounds like you got yourself a loose wire or pin. I bet if you pulled the wire behind the plug, one will pop out~Nick~
