As I was test driving my car yesterday my plug wire on cylinder 4 blew off. I have a 92 accord ex with a f22a1 what could cause this
plug wire blown off
antiseeze is so they don't become lodged in there and you can't get them back out. Nothing to do with being air tight. The other thing that keeps them airtight besides the threads is the crush washer. They are designed to be crushed once. If you remove them and reinstall the spark plugs, they could leak
Originally posted by ray719 View PostHow would I fix that just tighten it upOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Yes why spend 10$ to make sure it is done right.
You do not want to over torque your spark plugs.
Go to the store and buy some ngk, then use a properly calibrated torque wrench to torque them to the correct specs.
You are screwing a steal plug into an aluminum head, guess which one wins the battle.
Originally posted by Ghetto_CB7 View Postalso for the wire to pop off probably means you are running non honda or non ngk wires.
I never recommend this.
Even 20 year old junk yard wires are better and more reliable then bosch premium wires and random ones from auto stores.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by dj_ender View PostJust try tightening it up first, THEN if it still does it, remove the plug and see if the ceramic part spins freely inside the metal housing. There's no need to run right out and buy a new plug, yet.
Originally posted by Jimmy22 View Postspark plugs are cheap. Id maybe check to see if its loose, but if its tight, i wouldn't try reefing it down. Id rather spend 2 dollars on a new spark plugOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
