Whats this attached to the intake manifold?
    On my recently purchased 91 accord, ive discovered a different item on the intake manifold, compared to my 93 accord.
    Wondering what it is, i know what the other parts are, and i also know its not the butterfly valve, as its just a single runners manifold.
    pic of it:
    Pic of the untouched block off on my 93.
    UKDM 93 CB3 Page (1) H22A U2Q7 LSD
    UKDM 91 4ws Page (3) OEM Minter
    NOW H22A U2Q7 SWAPPED
    i think it's an air boost valve?
    "My FOR SALE thread - Click here"
    MEMBERS RIDE
    99 SILVERADO
    WHEEL FLIP
      you are correct sir.
        I just pulled out my honda book just to figure out what it does myself
        As honda puts it
        " When cranking the engine, the air boost valve supplies additional air to the intake manifold to ease engine starting "
          I just adjected mine. Now when i start it up in the morning it doesnt shoot up to 1500rpm till its warm. It just idles at 900rpm
          Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
          MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
            I thought it was the FITV.
            Meaning Fast Idle Thermal Valve
            MRT
            sneaky motherfucker
              nah, fitv has coolant lines going to it
              I <3 G60.
                So we concluding its Air boost valve then?
                Can i ask why its on my 91 but not on my 93. If its a benefit to cold starting, and the 91 had it why did honda remove it for the 93 model?
                  Are you sure? I know the IAC has coolant going to it. From the description of the Air boost valve it's either the same thing as the FITV, or activated by it.
                  MRT
                  sneaky motherfucker
                    yes we are sure. coolant goes thru the IACV and the FITV. the air boost is a completely separate unit
                    2013 Ice Cream Cruise!
                    VIDEO: 2012 Ice Cream Cruise
                    August 3 ~ Omaha, NE
                    By 1320 Video
                    Member's Ride Thread
                      Have a look see yourself
                      Both the IAC and FITV have coolant lines, the air boost valve does not. Take a look at your own car yourself and see.
                        Ps: Eacv = Iacv
                          Ok thanks everyone, all cleared up!
