abs light on
    abs light on
    i've been meaning to take care of this for awhile. my abs light comes on after i go aways down the street when i drive. i still can stop fine- brake pads and fluid are good. any idea what's causing this?
    Pull the code.
    http://www.cb7tuner.com/vbb/showthread.php?t=21259
      Try making sure the connectors to the brake reservoir are good.
        It may be one of your ABS sensors located behind the wheel that indicates which wheel is locking up when you apply the brakes. Make sure all the ABS connectors are connected. (ABS module underhood)
