I bought a 1991 accord lx with 256k miles changed the water pump , spark plug and wires . When i go turn on car the car starts off normal it idles past 1200 rpm and then the rpms just drop slowly and it starts to bogg and die. Also when it starts to bogg down it throws "sport" mode flashed for like a second or two. Im guessing maybe it could be the , fuel pump, main relay, or the fuel filter ? Any help will be appreciated .
Car starts , bogs , and dies !! Main relay???
The main relay controls the fuel pump. If the engine is running even for a short time on repeated attempts, it is getting fuel... which means the relay is working. You'd have to check fuel pressure at the rail to determine whether or not it's a pressure issue, which could indicate a failing pump, clogged line, or clogged fuel filter. I'm not sure any of those are particularly likely, however.
When you changed the water pump (and timing belt, I hope!) did you take care to properly reset the valve timing? If it is not set correctly, the engine won't run properly. Unless you're absolutely sure you did it correctly, that would be my first suggestion. Even if you're sure, I'd suggest double checking.
Also, the "sport" light flashing usually indicates a TCU error code. I don't think any issue with the transmission would cause problems with the engine, but it may be indicative of another problem. You can find how to read ECU and TCU error codes in the thread marked "READ HERE FIRST" at the top of this section (don't worry... nobody ever actually reads it first... it couldn't possibly contain useful information...)
If you lightly press the throttle, will it keep running? Make sure the Idle Air Control (IAC) valve connector is connected. You might even clean the IAC. The Fast Idle Throttle Valve (FITV) and air start valves will allow some air to get to the engine when you first start it, but they relatively quickly let the IAC take over controlling the air for idle. If it is unplugged electrically, or plugged mechanically, the engine won't idle.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
