what is a good tranny for my H22A
    so my fifth gear started missing really bad and grinding. I'm not sure what transmission is in the car as there's no label anywhere. I've called around to local shops in Phoenix and the repairs prices are ridiculous. just wondering if anyone knows what type of tranny i can substitute onto my engine without having to dish out 1k for just 1 gear getting replaced.
    Yea can swap and h22 h23 f22 i have seen a bseries tranny on a h22 aka h2b what motor you have
      Yes, any FWD non-ATTS transmission from any Honda equipped with an H or F series engine. A transmission from a VTEC Prelude will give you the proper gearing for your engine's powerband.
        i guess ima just have to find a h22 tranny for it thanks for the info guys
          Mines in the process of chewing up the input shaft bearing, good thread.
            I can give you a number to a guy who can rebuild your H tranny for cheap, locally in AZ, he's in the East Valley area near McKellips and the 202. His garage is literally strewn with trannys when I went over there and dropped it off. He does about 5-6 rebuilds a week.
            I had mine rebuilt for 200 and the he replaced the 5th gear syncro/sleeve set, installed new mainshaft and countershaft bearings and installed my F22 5th gear for better highway fuel economy. I think the turnaround time was about 5 days. I had to remove the tranny and reinstall it myself though.
            All in all, plan on spending about 350-400 with him including parts. A 5th gear sleeve set and two bearings cost me about 200 from Honda.
            member's ride thread
            91 Accord SE 176k
              I have a M2F4 usdm transmission on my H22a and it feels alot better than the F series, only thing i dont like is 5th gear on the freeway im at 4k going 70mph
                rebuilding it sounds good for that price send me his info i will contact him. this tranny aint gonna run much longer
                  I have an Accord tranny on my H22 and it's does just fine, but as Deev said, it's not geared for what the H22 likes. I still had fun with mine when I drove it. Only major down side is losing quite a few RPM's between gears (6500ish to about 4700ish RPMs) thus VTEC isn't engaged. But that's if you can't find any M2xx. Just for further info if you don't want to rebuild or buy another. Just know you have the option, as stated above.
                  The CB7 Collector.
                  92 LX Coupe F22A1
                  2013 Toyota Corolla S
                  92 EX Sedan F22A1
